what is the fastest all motor set up out there? ls/vtec, h22, ext...
i was wondering what is the fastest all motor out there and what set up are you using.
i have 2 choices, all out all motor ls/vtec or h22.
i seen a lot NA h22, and ls/vtec run low 11's but has anyone ran lower than that?
Re: what is the fastest all motor set up out there? ls/vtec, h22, ext... (projectef)
Re: what is the fastest all motor set up out there? ls/vtec, h22, ext... (njn63)
oh yea. Jeremy Lookofsky went 9.33 @ 145 at E-town. This is nothing near a street car though. Full tube chassis, etc.. Everyone's running K's. As far as street cars, Inline pro/Green Goublin went 10.8's?? in street stock, full weight EG hatch. He's also running a K.
Hope this helps.
Hope this helps.
Re: what is the fastest all motor set up out there? ls/vtec, h22, ext... (kpowerdhatch)
You may want to consider a fully built all motor LS! Dependability and speed.
King of the One Liners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpowerdhatch »</TD></TR><TR><TD CLASS="quote"> As far as street cars, Inline pro/Green Goublin went 10.8's?? in street stock, full weight EG hatch. He's also running a K.
Hope this helps.</TD></TR></TABLE>
thats because jeremy is a genius
If you have a nice chunk of change then go K24/k20 swap
Moderate- H2B has some pretty good potential
You can throw together a b20 for a decent amount and have some respectable times.
You also have to realize that suspension, tires, weight and driver abilities play a huge part in ETs.
yeah i know there is a lot of k-series out there, but i;ll stick with my h-series. i have a semi built ls/vtec, but then i tryed h22, n i love it. the only way im going back 2 b-series, is if i go boost. i dont have room in my engine bay 2 turbo my H.
i was thinking, i might use the prelude type s pistons, when i do the build. because i dont want the comp.. 2 hight, dat i always ahave 2 use 93 oct.. or higher. and i want to drive it on the streets. "what is the fastes street all motor out there?"
Re: (projectef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef »</TD></TR><TR><TD CLASS="quote">i was thinking, i might use the prelude type s pistons, when i do the build. because i dont want the comp.. 2 hight, dat i always ahave 2 use 93 oct.. or higher. and i want to drive it on the streets. "what is the fastes street all motor out there?"</TD></TR></TABLE>
Search
/thread
Search
/thread
