What is an afordable wide band A/F setup..?
Hey guys.
I am tinking at purchasing a A/F gauge setup to run on my poor mans type r then my b20v in a couple of months. I already have the b16 head and ctr cams to put on my b18c1 block with itr pistons.
What is an afordable setup. I looked up the AEM Wideband UEGO Gauge wich runs for about 200$. The engine is in a 97 gsr and will be tunned with an p28 ecu.
Any ideas/hints/links are greatly apreciated.
Thanks
Thanks
Re: What is an afordable wide band A/F setup..?
All Motor Mentor
1 Post
The AEM is affordable but in my and many others experience, aren't the most reliable. I would look at the PLX, Innovative, FJO, NGk widebands.
After researching several brands, I've decided to go with with the PLX SM-AFR
http://cgi.ebay.com/ebaymotors/PLX-D...Q5fAccessories
No calibration needed unlike some other brands
Im leaning more towards an Inovative unit.
Thanks again guys
i dont know why AEM gets a bad rep on this forum, i have never seen one fail other than a dead sensor, this happens to all wideband setups. one of the big magazines did an impartial wideband shootout, innovate and AEM tied for the most accurate, PLX on the other hand was over 1 afr point off, that's really messed up.
latency also important, but if you can hold a steady load tuning for this is no problem as long as your afr's are accurate!
so here is the link to one of the impartial magazine shootouts, judge for yourself http://www.paceperformance.com/pacep...ndshootout.pdf
doesn't aem, innovate, and maybe others, still use the bosch lsu 4.2 anyway? I have own the innovate and aem uegos, the only failures I have had was the o2 being mounted horizontal on my hytech header. added another o2 bung with it more vertical and no problems since. Other than that I go through a wideband about in a 1 1/2 year, depending how much you drive and what fuel you are running.
The sensor should be mounted in a 10 PM to 2 AM position facing down, never horizontal or facing up.
Also, that wideband shootout test seems flawed. Many of the test results are "subjective" results, and without any statistical data on the accuracy and latency readings, those numbers can also be misleading. I do analytical testing for a living and trust me, you can make any data look good or bad with some creative graphs and figures.
^^^^ I was looking at the ntk sensors, but chickened out and stayed with what I have always used. Since you have experience with the ntk, It must be similiar in accuracy, and evidentially last longer. I always seem to steer away from bosch pieces other than fuel pumps, and since ngk makes widebands it seems like a more familiar choice for me. But I ended up staying with the lsu4.2. How comparable are they?
i got a used plxm300 kit on here for 100 and just for shi*s i brought a new sensor and i love it 2yrs strong the best money i spent very easy to install black,white and ground
Thanks
I don't know what more you could ask for in an AFR accuracy test, it's much better than some kid on the forum saying X brand o2 wideband is the best cuz all by homies use it.
Im loking for something thats reliable and will be good for a Daily Driven car.
So, so far i am loking at getting the Innovate A/F DB Gauge.
No one answered my question. Will the o2 sensors work with e85. I read that they go out faster with e85 fuel..?
the shootout used 2 different bottle of calibrated lab gas, i will quote the shootout write up here, the bottles "were formulated to SAE standards for .8 lambda and .895 lambda (11.76 AFR and 13.15 AFR respectively) As an added data point, we used Westec’s expensive ECM LambdaPro. (Incidentally, the LambdaPro read dead on for both calibrated gases)."
lol, then you go use that wideband and dial your afr's, it's okay for you to be off by one whole afr in any "session"? i guess it doesn't matter much with granny tunes tho, i get it.
you guys think exactly alike, i can tell by your same jobs, even your sigs are laid out identically??
if a wideband ever read that far off once warmed up it should find it's way into the dumpster.
i personally think aem wideband are very easy to install, but i don't think they as accurat then innovative lc-1, i been use lc1 to tune, and seen like thats what all the guys running out there.
Thanks
So far i have two options. I cant decide wich one to get.
option # 1- Innovate LC-1 Wideband o2- 190$
or
option # 2-PLX DM-5 Wide band O2 52mm Display + SM-AFR. 240$
My buddy ho owns a BMW said that most of the bmw guys run PLX widebands on theyre bimmers and like them.
Thanks
innovate would be my choice.
plus the WB sensors are 01+ front o2 sensors for 1.8T's and VR6's making them CHEAP and easy to get when/if you need to.
calibration isnt a bad thing. lol. i would rather have a product that offers calibration, instead of one that does not. you dont have to calibrate the innovate if you dont want to. but at least you have the option.
Thanks
Thanks
