Valve spring tool - Honda-Tech
Valve spring tool
Old 10-12-2011, 09:44 PM   #1
ill fast's Avatar
Default Valve spring tool
What valve spring removing tool do you guys recommend for removing valve springs when the head is still bolted to the block
ill fast is offline   Reply With Quote
Old 10-12-2011, 10:22 PM   #2
cibao2ner's Avatar
Default Re: Valve spring tool
cibao2ner is offline   Reply With Quote
Old 10-12-2011, 10:57 PM   #3
nus_dogg's Avatar
Quote:
Originally Posted by cibao2ner View Post
Do you have that tool? How easy is it to use with head still on the block?
nus_dogg is online now   Reply With Quote
Old 10-12-2011, 11:03 PM   #4
cibao2ner's Avatar
yea i have the bluepoint version...for u to use it with the head still on the block ur gonna need a leakdown tester..and crank up the air pressure to like 150psi so the valves dont drop..
Old 10-13-2011, 05:37 AM   #5
PyroProblem's Avatar
Or you can put some soft nylon rope down the spark plug hole and rotate the piston up to TDC.
The nylon rope will keep the valves closed if you don't want to buy a leakdown tester just for this one job.
PyroProblem is offline   Reply With Quote
Old 10-13-2011, 07:26 AM   #6
GagnarTheUnruly's Avatar
GagnarTheUnruly is offline   Reply With Quote
Old 10-13-2011, 01:03 PM   #7
ill fast's Avatar
Thanks for the recommendations. Just wondering how easy is it to work wit the eBay one
Old 10-13-2011, 01:15 PM   #8
Krut's Avatar
Quote:
Originally Posted by GagnarTheUnruly View Post
This one is awesome. I wouldn't get anything else.
Krut is offline   Reply With Quote
Old 10-13-2011, 01:45 PM   #9
m_shake's Avatar
Ahhh beat me to it
m_shake is offline   Reply With Quote
Old 10-14-2011, 08:36 AM   #10
h2.4's Avatar
no to all of those above. I used the first one for a long time. Pita. Use compressed air as you would with the above tools, to anybody that hasnt used the tool I'm linking, You're gonna save waaaaay more time using the one in this link. Usually takesabout 5 min. per cylinder once cams and stuff is outta way. 20 mins for all four cylinders. Might take you a little while to figure out how to use it properly, but no joke, 20 minutes, 4 valves per cylinder.http://buy1.snapon.com/catalog/item....re&dir=catalog
h2.4 is offline   Reply With Quote
Old 10-14-2011, 09:18 PM   #11
nus_dogg's Avatar
Oh ok. I have Euro Export valve spring compressor tool that makes life's 10x easier. Thats the tool I used to do my sk2 pro valvetrain.
Old 11-23-2011, 06:11 PM   #12
iwannarace's Avatar
Quote:
Shinanigans! I've been trying to use the lisle version of this tool which is basically the same thing... I'm not a small guy and compresing the spring enough for the keepers to sit has been frikn impossible... I will now be looking for a different method unless you can teach me how to use it "properly".
iwannarace is offline   Reply With Quote
Old 11-23-2011, 06:16 PM   #13
I think you're supposed to hit it with a hammer. Are you doing that, or trying to press it with your body weight?
Old 11-23-2011, 06:37 PM   #14
Fink29's Avatar
I use the one in the first link and I like it. Once you set it up you can take off each valve without taking the tool off for each cylinder.
Fink29 is offline   Reply With Quote
Old 11-23-2011, 06:42 PM   #15
iwannarace's Avatar
It's my understanding you hit it with a hammer to remove the valvesprings, which I've done. i'm trying to reinstall now and using body weight which is frikn impossible... i don't want to buy another tool but i guess i may have to.
Old 11-23-2011, 06:46 PM   #16
Fink29's Avatar
The euro export version looks to be a little easier to use.
Old 11-23-2011, 07:00 PM   #17
iwannarace's Avatar
Who wants to loan or sell me one?
Old 11-23-2011, 07:03 PM   #18
BiggieBert's Avatar
I personally like this tool, worked very well for me.
BiggieBert is offline   Reply With Quote
Old 11-23-2011, 07:05 PM   #19
Fink29's Avatar
If I wasnt on the other side of the usa I would def let you borrow mines. Someone step up and help a fellow member out.
Old 11-23-2011, 07:10 PM   #20
h2.4's Avatar
Quote:
You just have to make sure it is squared up when you press down on it. Also push it down slowly, just till you hear the keepers "click" into place. If you push past that point, they won't set in. so just push firmly and slowly till they "click" then let up and should both be set. I would never use anything else. way too slow, attach tool, screw down, fiddle with keepers, lose mind, repeat. f that.
Old 11-23-2011, 07:16 PM   #21
I have the one in the Ebay link and it worked great. Also, you don't have to put compressed air in the cylinders. With each cylinder at TDC the valves only drop about a 1/4". As long as you make sure each cylinder is at TDC for the given valve stems you're replacing you'll be fine (this is the way I did it and I had no issues).
crxsirg is offline   Reply With Quote
Old 11-23-2011, 07:51 PM   #22
iwannarace's Avatar
I must just be a weak ***** and can't push it down enough... any one wanna sell me one of their used compressors?
Old 11-23-2011, 08:43 PM   #23
DDTECH's Avatar
Bought the tool listed, both infact. I use them on the cars i work on.. Both ways work.
Bought one from matco and snapon..
DDTECH is offline   Reply With Quote
Old 11-24-2011, 08:48 PM   #24
JustOneOrTwoPosts's Avatar
I've used this tool on my mr2 and it was super fast and easy. I think the website has video's of how it works too. http://www.toyotool.com/
JustOneOrTwoPosts is offline   Reply With Quote
Old 11-24-2011, 09:18 PM   #25
ill fast's Avatar
In the end I ended up making my tool similar to that eBay one
Lisle valve spring tool for B, H and D Series !!! BUY THIS wasanissanFL For Sale 17 11-01-2015 10:27 PM
WTB B Series VTEC valve spring removeal tool wasanissanFL Want to Buy 4 03-26-2015 01:13 PM
gsr head removing valves which tool Kr4nG Tech / Misc 12 11-19-2009 02:09 PM
Spring Swap mark7901 Honda Civic / Del Sol (1992 - 2000) 2 05-06-2005 08:47 AM
valve springs removal mntdewred Tech / Misc 2 07-23-2002 02:11 AM
Tags
compreser, euro, export, honda, hondatech, removal, screw, sell, spring, stores, tool, tools, uero, valve, vave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
