Timing belt issue and question.
I am building and ls vtec. b16 head milled .020 b18a block. Gsr w/p and timing belt and oil pump. Im having the timing belt off 1/2 a tooth issue.
I was wonder if Honda sold Belts that are 1 tooth less for milled heads. I know other manufacturers do. And at the same time Will I still have the issue since Im only a half a tooth off?
Re: Timing belt issue and question.
Nope. Use a gsr timing belt.
shouldn't be a problem lining everything up, to make it super tight, put a coat hanger under the lip that extends from the back of the tensioner, and pull up.. and tighten.
SO your telling me if I made it super tight it will line up? I have made it si its tight so I guess Ill make it "super tight" and see.
