Suggestions Needed: K20A3 1st Level Engine Modification list
Hey guys, I'm getting a 2003 Acura RSX type-S and I'm looking to upgrade it and increase my over all performance. I already am planning on getting a racing intake manifold, upgraded throttle body, a CAI, racing headers, cat delete (I'm blessed to live in a area that doesn't have emissions testing), racing exhaust, ECU tune, and maybe a better camshaft. So, what kinda of camshaft? I don't feel like having to do all my valves, and springs and stuff. Just the cam. And boosting is completely off the table. Thanks!
re: Suggestions Needed: K20A3 1st Level Engine Modification list
This is just my advise. Theres a love and hate with all motor and FI but once you drive a boosted setup you get hooked, put it this way i was a all motor junky for the longest time once i ventured and bit the bullet on a sc kit the rest was history theres more potential for power which is everyones main objective when thinking about modifiying there cars for whatever reason. GL
In this case take the whole idea of those parts mostly benificial for N.A applications out your head and think about either 2 reliable power adders for the time and money invested which would be forced induction. The amount of money you spend on those parts will not give you as much power or satisfaction as you would get from simply focusing on a supercharger bolt on kit or a off the shelf semi bolt on turbo kit. You will thank me in the end because when you add up all the money you spend to get 240 hp you could of made double the power for around the same give or take. Then go from there.
I agree with wunfstgsr, the stuff you listed won't make large power increase, but if you are dead set on sticking with n/a I would suggest looking into a k20/k24 set up. A good friend of mine has a stock tsx bottom end (with a type s oil pump) with a k20 (can't remember which one right now) cylinder head that is ported and polished, RBC intake 74mm throttle body, 3.5" custom intake with a v-stack, RDX injectors, tuned on kpro, skunk2 header, 3" exhaust and prayoontoo camshafts (once again can't remeber which ones, but they aren't huge) and he laid down 270whp on a mustang dyno (these read a bit on the low end compared to other dynos). This is in his K swapped EM2.
intake manifold: RBC
throttle body: 70-74mm
Intake: 3 or 3.5 inch piping
Header: skunk 2 alpha is good and inexpensive
Exhaust: have one custom made, most shelf exhaust are pretty restrictive. 3inch is a must with k series. Mandrel bends make the most power. Aluminized is fine. Buy a nice muffler (vibrant, borla, etc) and a resonator.
ECU: kpro
Cams: cartel DIC. A guy I know made 12-15whp from like 4k to 8500 rpm on a stock k20 with those cams. Nothing crazy but you can use stock valvesprings. Anything bigger than DICs requires upgraded springs.
With a fair reading dynojet and a competent tuner, 240-250whp should be no problem.
EDIT: Nitrous is the ****. A 75-100 shot on k20 is tons of fun and well within the limits of safety for a stock block.
Look into ITB's but good luck beating your buddys car going n.a but i hear you about throwing in a SC later down the road so your not really gonna hurt the car doing bolt ons for now, i was just stating skip all that and go with a SC kit with a few mods you can make decent power.
defcon1Racing
01-16-2003 01:21 PM
