stock crank pulley or aftermarket???
Old 08-19-2010, 09:13 AM
horn12007's Avatar
Default stock crank pulley or aftermarket???
ok Im gonna try to keep this somewhat short. i have 2 motors apart. building one. my b20 (not building) had a crank timing gear and an unorthodox racing 1 belt pulley. my b18 had the stock harmonic balancer. now im building the b18 and have it somewhat together and wondering which pulley set up to use. I understand the unorthodox pulley is way lighter which is good, but I understand that you gotta keep everything with the harmonic balancer. main question is it bad to use the lighter racing pulley over the stock harmonic balancer?
Old 08-19-2010, 09:25 AM
night's Avatar
Default Re: stock crank pulley or aftermarket???
Back in the day when I was up to date on everything it would be a solid no to aftermarket pulleys. Now though I am of the opinion the rubber insert is more about the shock of the compressor engaging, so, IMO, if you don't have A/C I think it doesn't make any difference.
You will no doubt hear otherwise though. Personally, I am running stock with the p/s ribs cut off and then turned smooth on a lathe.
Old 08-19-2010, 01:50 PM
horn12007's Avatar
yea im not really sure. eventually i want to sleeve the b20. I just don't want something like that to jack up my motor. anyone else have opinion on it? also what are the 2 sensors on the passenger side of the head (under the vtech solenoid). for some reason I cant find mine and cant really look them up if i dont know what they are
Old 08-22-2010, 07:06 PM
horn12007's Avatar
bump.....for help. lol
S2kRyan
02-20-2011 01:48 PM
crashsvg
11-04-2008 06:39 AM
DC2-JRSC'd
08-01-2005 07:47 AM
DB8
04-12-2003 04:41 PM
badCRX
04-26-2002 08:24 AM
Quick Reply: stock crank pulley or aftermarket???
