Lightweight crank/flywheel
Old 05-14-2010, 12:24 AM
hondamn1320's Avatar
Default Lightweight crank/flywheel
So I finally got my car running and I'm a little stumped on a little problem. It seems that my idle can't "catch" itself after a little spirited driving. It will just die out. Could it be because the RPMs are falling too fast, or is there something further that I'm missing.
I know I need to redo the valve lash on the intake side. Not sure if that will have anything to do with it.
I didn't have this problem on my old setup.
Old 05-14-2010, 09:51 AM
Default Re: Lightweight crank/flywheel
10-4
Old 05-14-2010, 11:44 AM
Scott_Tucker's Avatar
You are going to want to run the idle rpm higher if you are running a lighter flywheel/crank to keep it from stalling. It could also be a tune issue.
Old 05-14-2010, 02:12 PM
Thanks for the advice. I think the idle dropped a few hundred rpm, so I need to adjust that.
jarven093
05-16-2007 10:29 AM
jarven093
05-16-2007 10:26 AM
darockstar
03-10-2006 05:00 PM
TeknoJunki
14
08-10-2004 10:05 AM
Spade
01-08-2003 01:51 AM
Quick Reply: Lightweight crank/flywheel
