spark plugs on ls/v
Old 05-08-2008, 02:20 PM
ceyazzie's Avatar
Default spark plugs on ls/v
for those that have ls/vtec.. what spark plugs r u guys using and what is good.. i have a ls/vtec: ls crank and rods with type r pistons stock b16 head.. the spark plugs are going out and need help.. i always fill up on 91octane..
Old 05-08-2008, 02:32 PM
groundzerocivic's Avatar
Default Re: spark plugs on ls/v (ceyazzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceyazzie &raquo;</TD></TR><TR><TD CLASS="quote">for those that have ls/vtec.. what spark plugs r u guys using and what is good.. i have a ls/vtec: ls crank and rods with type r pistons stock b16 head.. the spark plugs are going out and need help.. i always fill up on 91octane.. </TD></TR></TABLE>
stock B16 or GSR NGK plug here
Old 05-12-2008, 12:37 PM
ceyazzie's Avatar
i have the b16 and it wore and i got some back fire, ill try the GSR
Old 05-12-2008, 12:51 PM
honda_ef9's Avatar
Default Re: (ceyazzie)
12-1 cr bkr7e ngk
Old 05-13-2008, 03:02 AM
ceyazzie's Avatar
Default Re: (honda_ef9)
thanks....
Old 05-13-2008, 07:05 AM
killerpenguin21's Avatar
i run NGK V-power R5671A-8 plugs. bam bam has them listed in the write up for building an ls/vtec as being for 12.0:1+ cr. i have p30's with a gsr head so my cr is kinda high. the plugs are good, have a slot for better spark travel (if search wasnt down id find the article by rocket).
but they get my vote...either those or the 7's.
Old 05-19-2008, 04:55 PM
JakeSpec's Avatar
Ngk Pn 5238 V power Cold 9's
Old 05-19-2008, 05:07 PM
Default Re: spark plugs on ls/v (JakeSpec)
9's?!?!?
i just had my car tuned/dyno'd and the 8's are too cold. how the hell are you running 9's?
Old 05-19-2008, 05:13 PM
JakeSpec's Avatar
Default Re: spark plugs on ls/v (killerpenguin21)
14:5:1 86x89mm
Old 05-19-2008, 07:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote">14:5:1 86x89mm</TD></TR></TABLE>
well you shoulda specified that
Old 05-19-2008, 07:27 PM
mx621's Avatar
NGK bkr7e-11's here. 12.2:1 comp (aprox)
Old 05-19-2008, 08:03 PM
Default Re: spark plugs on ls/v (mx621)
yeah i need to try a set of 7's, but im not that good at reading plugs to see which is better.
Old 05-19-2008, 11:28 PM
lunatics209's Avatar
i use denso iridiums. for nitrous i use ngk number bcpr7es11.
DA9teg93
08-19-2005 11:26 AM
Toadfart
06-22-2004 11:07 PM
made in JAPAN
09-19-2003 10:00 AM
Quick Reply: spark plugs on ls/v
