Will Skunk2 stage2 cams sufficiently perform w/ a stock B20VTEC Engine setup??
#28
I like the tuna here
Re: Will Skunk2 stage2 cams sufficiently perform w/ a stock B20VTEC Engine setup??
I don't think a stock B20 bottom end mated to a GSR or B16 head will result in enough compression to really take advantage of Skunk2 Pro2 cams, unless maybe you're referring to the Tuner2's?
#29
Neither will work without fly cutting the stock valve reliefs of the PHK/P3F piston to accomadate the increase lift of tuner2's. Pro2's would not work well here due to lack of compression. I do think they would make more high RPM power over the tuner2's if you revved out the engine and used a larger volume intake manifold but the power curve would be narrow and the stock bottom end wouldn't like 9k+ revs.
