resurface head
Old 10-29-2011, 01:22 PM
nelson9994's Avatar
Default resurface head
okay guys I have a resurfaced head and block but I have taken the head off about 4 times (and torqued down) and put about 30 miles at the most on the motor. I'm about to put a new HG because the one in there is leaking. Do you guys think I will need to resurface the head or should I be good?
Old 10-29-2011, 02:51 PM
N/A
Purpose Built
N/A's Avatar
Default Re: resurface head
Fail
Old 10-29-2011, 06:36 PM
mouab18c1's Avatar
No need to resurface the head.
Old 10-29-2011, 07:44 PM
PyroProblem's Avatar
If you blew 4 headgaskets in the last 30 miles, I think you should at least have it checked. Something obviously isn't right...
Old 10-30-2011, 10:09 AM
nelson9994's Avatar
I didnt blow 4 HG.... heres the story
i did a 1 layer first time then cr was goonna be at like 12:8 so i took it out and did the other 2 layers
then i said f it took it off again and put a new one in
i put it on upside down so it was leaking alot
then i took a used one i had and put it in this one looked ok but it had hella miles
and is leaking too
oil (alot)
so i ordered a brand new one this time
Old 10-30-2011, 10:27 AM
Moderator
TheShodan's Avatar
and is leaking too
oil (alot)
Wow. Unfortunately that seems as though there was lot of effort that was rather wasted
Old 10-30-2011, 11:21 AM
mouab18c1's Avatar
Aka NOOB
Old 10-30-2011, 12:54 PM
Practice makes perfect!
If the head and block have been milled, make sure your dowel pins aren't keeping those corners of the head from seating all the way (can cause oil leaks)...
Check them to see if they need milled down too...
Old 10-30-2011, 06:44 PM
nelson9994's Avatar
im going to mill them down a bit anyways. my question is do you guys think the head needs to be resurfaced or should i be good
Old 10-30-2011, 07:04 PM
h2.4's Avatar
put a precision straightedge on it and see what feeler gauges can go under it if any. I think factory manual says .002" is max warpage. but if there is any warpage, I just get it decked anyways.
Old 11-02-2011, 07:57 PM
nelson9994's Avatar
I dont have a straightedge or the money to buy it right now... I will eventually check it when I get the money...
BTW... how do heads lose their straightness??? is it once is torqued down, or if it over heats or the miles or what.... because even though I am not sure... after 40 miles it doesn't sound like alot of miles for it to need a resurfacing or does it because it has been torqued 4 times or what?
eh2_Trav
Transmission & Drivetrain
01-21-2019 11:00 AM
cBrown05
10-09-2009 07:48 AM
butch11a
Welding / Fabrication
01-03-2005 07:46 AM
Boost2NA
08-04-2002 06:48 AM
Quick Reply: resurface head
