REMOVING THE CRANKSHAFT PULLEY...???
Everyone i have talked to has told me i need a specail tool, the crank pulley removal tool?? I have called around everywhere and no one has this tool. I tried forever to remover the bolt. How do i get the crankshaft off!??? help!!
All Motor Mentor
1 Post
Re: REMOVING THE CRANKSHAFT PULLEY...???
That's the beauty of an air tool, it activates so quickly that rotation problems aren't usually an issue. Is the crank out of the car or something? Either way sounds like you need to turn up the air pressure or use a higher torque impact gun to remove the bolt.
if the motor is still on the car then stick a screwdriver in the teeth of the flywheel and it should jam the crank in place once it hits the block. use a breakabar in this case. if the block is out and the crank has the main caps on then stick an extension between the counterweights and the block and use a airtools..
jodyboy
13
07-01-2012 11:52 AM
sayanything
09-22-2010 04:47 PM
kid_layzie
04-02-2004 09:52 AM
94vtecmn
04-21-2003 12:08 PM
