Rebuilt D17A1 Engine Pre-Lube procedure?
New User
I am finishing to put together a re-built D17A1 longblock for my 03 Civic. The remanufactured engine comes with a warning that I need to Pre-Lube the engine by pressurizing the oil or by turning the oil pump until oil flows to the head.
How can I accomplish this in the most economic way?
Thanks!
Thanks!
Re: Rebuilt D17A1 Engine Pre-Lube procedure?
Pull out the spark plugs and pull the ecu fuse so it doesn't inject fuel as you crank it over or unplug the injectors, either way works. when i did mine i just cranked it over for 5-10 secs let it sit for a few seconds then repeated. put everything back together and fire it up!
EG-SIXV-TEC
12-05-2013 06:26 PM
streetracerof06
05-08-2006 06:09 AM
