Rebuilding B18C(JDM ITR) with P30's - Honda-Tech
Old 12-01-2009, 07:08 PM   #1
SOHCunderdog's Avatar
Default Rebuilding B18C(JDM ITR) with P30's
Good night H-T.
I have been doing a lot of research lately as my motor is ready for a rebuild. I do not want to overspend on buying forged internals when oem parts will do the job. I do intend on using arp rod bolts, head and main studs. No headwork to be done at this point in time.
So far while searching on this forum, I have found that people use the P30 piston in GSR's and such, but I haven't come across anyone using them in an ITR motor. I know the compression will vary a bit with the ITR head being different from the GSR head. I would like to bump the compression up a few points, but nothing drastic or pushing the limits. I know that I need to stay away from the CTR pistons as well.
Here are some info you all might want:
Goals: Hit 8.8sec on 1/8th.
Use: Drag(Street tires) and Auto-X
Budget: What a pity.....
Car and mileage: 96 Honda ITR. +140,000km
Thanks in advance for your input.
SOHCunderdog is offline   Reply With Quote
Old 12-06-2009, 05:42 PM   #2
crxfornow's Avatar
Default Re: Rebuilding B18C(JDM ITR) with P30's
p30s would lower your compression
crxfornow is offline   Reply With Quote
Old 12-06-2009, 07:58 PM   #3
I think he means the JDM p30's
thundernoodle is offline   Reply With Quote
Old 12-06-2009, 08:00 PM   #4
Quote:
Originally Posted by SOHCunderdog View Post
Good night H-T.
p30 will incrase your compression .2-.3
Dont waste you money, skim your head .015"
and raise your compression to 11.5 - 11.6 with the jdm Itr piston
and get cam gears flash your computer and have a nice day
4doortypeR is offline   Reply With Quote
Old 12-12-2009, 05:42 AM   #5
Dont trust any machine shops to mill my head where I'm from.
Any other input guys. I basically just want to increase my performance without spending a pile of cash on forged internals.
Old 12-12-2009, 10:06 AM   #6
dj-t's Avatar
Aren't there company's out that makes thinner head gaskets to increase compression?
dj-t is offline   Reply With Quote
Old 12-19-2009, 11:00 AM   #7
1tuffbb6's Avatar
Why would you stay away from the CTR pistons?
1tuffbb6 is offline   Reply With Quote
Old 12-19-2009, 11:23 AM   #8
All Motor Mentor
00Red_SiR's Avatar
Quote:
it might have something to do with the 100+ threads that tell you to stay away from them and why. There are better alternatives.
00Red_SiR is offline   Reply With Quote
Old 12-19-2009, 11:30 AM   #9
kulo's Avatar
jdm p73s are nice
kulo is offline   Reply With Quote
Old 12-19-2009, 02:28 PM   #10
1tuffbb6's Avatar
Quote:
Links please.
Old 12-19-2009, 03:27 PM   #11
All Motor Mentor
00Red_SiR's Avatar
Links please.
search please.
Old 12-19-2009, 03:36 PM   #12
1.5Slowmatic's Avatar
hes from MD, give him a break
they have a HUGE dome which hinders flame travel. you can achieve the same compression with regular ITR pistons and milling the head. Just people hear they are from the type r and they instantly think they are the best piston ever
1.5Slowmatic is offline   Reply With Quote
Old 12-19-2009, 03:42 PM   #13
mar778c's Avatar
OP just run RS machine pistons. They work exceptionally well with no head milling. Compression is not nearly as important as running a good intake, header, and exhaust.
mar778c is offline   Reply With Quote
Old 12-19-2009, 03:55 PM   #14
1tuffbb6's Avatar
Which would have a higher compression between the P73 JDM ITR or the JDM P30 piston in a b18c5 long block?
And thanks for the people who aren't d-bags, what exactly would I search for "why not to use CTR pistons?" *** hat
Old 12-19-2009, 04:05 PM   #15
http://www.zealautowerks.com/bseries.html
have fun. the ITRs are slightly higher. They sit closer to zero deck and have a smaller dome than the P30's do
Old 12-19-2009, 05:05 PM   #16
All Motor Mentor
00Red_SiR's Avatar
lol... Seriously I wasn't being an *** hat. I'll assume you haven't been to the All Motor forum before or at least in quite some time as this is one of the most discussed subjects in this forum. I asked you to search because I know there's a lot of information available if you'd at least make an attempt to find it. I'm not in the habbit of giving info to people that can easily be found with a little effort on their part. You could use your imagination and play with the search function and see what comes up, you could start off by typing in CTR or PCT pistons, narrow the search to the All Motor forum and see what you get. you could even type that question into google and see what you get...it's really that easy.
Old 12-19-2009, 05:22 PM   #17
1tuffbb6's Avatar
Thanks for the insight either way!
Old 12-19-2009, 05:27 PM   #18
kulo's Avatar
ff squad has a very nice write up on b-series pistons
http://www.ff-squad.com/tech/temp/pistons.htm
Old 12-19-2009, 05:36 PM   #19
All Motor Mentor
00Red_SiR's Avatar
Their compression measurements are off quite a bit when they talk about the PCT pistons installed in the various blocks.
Old 12-19-2009, 05:40 PM   #20
the search feature on this iste sucks since going vbulletin, not sure why, no other site has issues.
Old 12-19-2009, 05:52 PM   #21
All Motor Mentor
00Red_SiR's Avatar
I agree and will often Google my search inquiries as it leads me back to HT most of the time.
Old 12-19-2009, 09:33 PM   #22
egb18c5's Avatar
funny thing is, 8 out of 10 times i search, not only do i find what i want, but it derails me and i learn some thing else. you'll be surprised with what u find
egb18c5 is offline   Reply With Quote
Old 12-20-2009, 05:49 AM   #23
B20typeR's Avatar
i got b18c block gsr rods and crank wit jdm itr pistons...love it! its more reliable goin wit jdm itr pistons. wit ctr pistons u might be lucky ur car runs good wit 91. unless ur hometown has higher octane. heres my b18c wit jdm itr pistons
B20typeR is offline   Reply With Quote
b18b1 with itr pistons 215HPLSVTEC Acura Integra 50 02-07-2014 08:30 PM
USDM ITR Pistons in GSR Trying to BAR BC_Garage All Motor / Naturally Aspirated 29 07-03-2011 08:35 AM
b18c1 stock rebuild with USDM ITR pistons, need help with compression ratio/build sayanything Acura Integra 11 12-18-2010 02:08 PM
p30 or p73 pistons? 93egSLEEPER All Motor / Naturally Aspirated 6 12-19-2009 10:00 PM
b16a2/p30 pistons in a gsr bottom with itr head gundamgsr Tech / Misc 4 06-14-2004 06:00 PM
Tags
1151, b18, b18c, bump, buy, compression, gasket, head, hondatech, increase, job, layer, p30, piston, pistons, single, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
