Possible to tell if you have cams without opening valve cover??
#26
Re: Possible to tell if you have cams without opening valve cover??
well what would u want to know, turbo size? what kind of driving characteristics i would want? I mean this is down the road so I havent researched turbo models yet but I'm going to go with a relatively small turbo for good low and mid range power. I really dont want to rip apart the block and spend a large amount of money going to low compression pistons and new rods and crank so I can have a 400hp beast. only looking for around 225hp out of it.
#30
been looking at those premade kits, most say they are overpriced and if you build your own you'll save money and have a better setup. I have a friend of mine that has built many turbo setups working in a shop so I'll goto him and piece together a setup. I just wanted to build the top end first before slowly buying the turbo setup.
questions: do the valves play the biggest role on how high you can rev the engine? I've read by replacing the valves and springs with much lighter material is what will allow you to rev the engine past the 8k threshold of the b16 top end. this sound correct?
#31
Yes, most turnkey kits are overpriced...however they usually are complete and meant for your vehicle. Seeing as that most of your posts do not show you having an extensive knowledge base on the motor, a turnkey kit was what i recommended as new folks to the whole thing tend to gauge that it would be cheaper to piece a kit together.
It is much cheaper, but to only the folks that know what they want and need. In your case there have probably been thousands of guys planning to build their own kit and ending up spending double or more to get to the point where they are actually even able to install and have everything work. Let alone changing their mind as better deals come around on a particular manifold or turbo or waste gate or blow-off valve...the list goes on and on.
Do your friend with a shop, Honda-Tech and your self a huge favor and buy a bolt on kit. Even a used drag or Greddy kit would work just fine and be able to net you 225HP.
gser.typer
26
08-22-2009 04:25 PM
