Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
I wasnt sure where to put this thread since it isnt model specific or tech related more of a discussion. Anywerds
Stuck on what to build. I have a b16 head, a gsr head and a gsr block. I read a regular gsr will put down slight more power than a poor man type R also what kind of pistons should i run? Aftermarket gsr pistons or type R pistons? Would like others opinions on what to do. I also have a ls crank/ rods and block. Could put ls internals in the gsr block and have a stroked poor man type R? Or build a lsv with a b16 head. Decisions decisions. I jumped into this project without a plan in mind but i do know i want to finish a gsr engine. This discussion is just to get some ideas bouncing around. Let me know what you all think!
footwork mastery
re: Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
real answer - ls crank in gsr block with some type r pistons with gsr head because slightly higher compression
GDD answer - hondas are for poors
If you use that LS block you will have to run a catch can as you would have no PCV system with an LS block / VTEC head. And an oil line kit.
Frankly if I had a complete GSR I would just go with that. Why not just put the GSR together and slap the B16 head on the LS block? Wouldn't that make sense? 2 engines right there.
Moderator
This. But you may need to modify the crank to clear the squirters. That setup would make the most power.
Re: Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
Lol ok. SLEEVED makes better sense. B20 block IMO is a better option if cost is a concern.
xxnuttybarxx
10-25-2007 01:04 PM
