High idle need help fast!!!!
Old 12-26-2007, 11:38 PM
Tyler Con's Avatar
Default High idle need help fast!!!!
Okay guys i know you hate when i post about **** that has already been covered but i couldnt find a solution I did a motor swap and got a B16 and the idle used to rev to 3K then go back down then just repeat it so i bought a tps and now it just goes to 3k then slowly keeps going higher idk what it could be so if anybody has some ideas let me know. thanks and sorry again for posting but couldnt fined anything i havent tried already.....
Old 12-27-2007, 12:11 AM
moderator emeritus
98vtec's Avatar
Default Re: High idle need help fast!!!! (Tyler Con)
did you take the map sensor off for any reason during this?
Old 12-27-2007, 07:29 AM
onepoint6i's Avatar
sounds like you have a vaccum leak at the manifold..check your intake gasket/throttlebody gasket..make sure you have the right T/B gasket for the manifold..
apbtwhiskey
04-05-2013 01:51 PM
twentyhurtz
01-16-2009 08:30 AM
93SiPrelude
02-24-2008 10:39 PM
SimplyTron
01-26-2006 08:19 PM
loudassVTEC
10-05-2005 10:40 PM
Quick Reply: High idle need help fast!!!!
