Omniman Valve Springs with Brain Crower Steel Retainers
Old 03-11-2008, 06:42 AM
Chillinit's Avatar
Default Omniman Valve Springs with Brain Crower Steel Retainers
I'm in the process of swapping out my retainers due to the wear issues associated with Titanium. I'm considering going with a stock retainer or the steel ones that Brain Crower offers. Does anyone foresee any issues with running either of these steel retainers with my Omniman Valve springs? TIA.
Old 03-11-2008, 08:53 AM
Gong Show's Avatar
Default Re: Omniman Valve Springs with Brain Crower Steel Retainers (Chillinit)
Same question I asked yesterday. No feedback though.
Old 03-11-2008, 09:16 AM
Runnerdown's Avatar
I like to purchase and use valve springs and retainers that are designed to work together. Are yours actually worn out or is it preventative maintainence? From what I have seen from the omni stuff it holds up very well.
Old 03-11-2008, 09:23 AM
Rocket's Avatar
Default Re: Omniman Valve Springs with Brain Crower Steel Retainers (Runnerdown)
How hard is it to measure your springs' ID's and ask for the OD's of the registers (steps) on the retainer?
People answering this question would have to do the same, correct?
Old 03-11-2008, 09:30 AM
Chillinit's Avatar
Default Re: Omniman Valve Springs with Brain Crower Steel Retainers (Master of the Universe)
Correct. Unfortunately, I don't have the car accessible at the moment due to it being winter. Therefore, I am unable to measure any of my valve springs/retainers. Would the OD/ID of the retainer and steps be the only limiting factor in running a different spring and retainer combo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">How hard is it to measure your springs' ID's and ask for the OD's of the registers (steps) on the retainer?
People answering this question would have to do the same, correct?</TD></TR></TABLE>
Old 03-11-2008, 09:31 AM
Rocket's Avatar
Ask the manufacturers then.
Old 03-11-2008, 09:42 AM
Chillinit's Avatar
Its a given that the manufacturers would advise people to run their cams coupled with their valve train components. Would you disagree?
I'd like to hear from who run stock retainers with upgraded valve springs. I think BearEk does this but I could be mistaken.
Old 03-11-2008, 09:49 AM
Rocket's Avatar
You mean Brian Crower and Omnipower will not give you dimensions if you ask for them?
Old 03-11-2008, 10:13 AM
Chillinit's Avatar
I can ask the manufacturers however I don't know if that is the only limiting factor.
Old 03-13-2008, 09:42 AM
Gong Show's Avatar
Check out the post from BearsEK-KMSU
https://honda-tech.com/zerothread?id=1822679
Old 03-14-2008, 04:14 AM
Chillinit's Avatar
Default Re: Omniman Valve Springs with Brain Crower Steel Retainers (Gong Show)
Respect Gong. Thanks for the link.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gong Show &raquo;</TD></TR><TR><TD CLASS="quote">Check out the post from BearsEK-KMSU
https://honda-tech.com/zerothread?id=1822679</TD></TR></TABLE>
Old 03-14-2008, 04:22 AM
Gong Show's Avatar
No problem man. You have helped me out before. Just returning the favor.
Diggie
K Series
04-28-2019 02:07 PM
Quick Reply: Omniman Valve Springs with Brain Crower Steel Retainers
