blox tuner / comp. cams?????
Old 08-20-2006, 07:45 PM
96typeR's Avatar
Default blox tuner / comp. cams?????
I've been searching but cant seem to find what is the difference between the blox tuner series spec B, and the blox competition series spec B's???? thanks!
Old 08-20-2006, 08:07 PM
Touge Tuning's Avatar
from what ive read tuner = regular s2 series and competition series = pro s2 series. So tuner will idle like stock but lack low to mid power whereas the competition might idle a little rougher/higher but will have killer midrange.
Old 08-20-2006, 11:06 PM
Real_E-AT's Avatar
Default Re: blox tuner / comp. cams????? (96typeR)
Basically the comp. cams have wider lobes then the regular tuner series. Same profiles as tuner but wider lobes for more rocker contact and durability. Just like the Toda cams.
From their website: Competition Series - Cast with wider primary and secondary lobes, with Blox profile specifications
Modified by ChopSuey at 12:17 AM 8/21/2006
Old 08-20-2006, 11:45 PM
darklyte's Avatar
is it true that you have to change your rockers in order to use the compition series?
Old 08-21-2006, 05:00 AM
Natural Aspirations's Avatar
Default Re: (miner-dma)
I would have to think so, the rockers are worn a certain way and if you change the with of the lobe your going to change the contace patch.
Old 08-21-2006, 10:48 AM
RedZone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miner-dma &raquo;</TD></TR><TR><TD CLASS="quote">is it true that you have to change your rockers in order to use the compition series?</TD></TR></TABLE>
No it is not necessary to change the rockers.
Comp does not = Pro series of skunk
tbones
03-20-2007 04:00 PM
miller
03-16-2004 06:43 AM
Quick Reply: blox tuner / comp. cams?????
