Oil Galley plug on a b20v
Long story short, I do not have the tools nor know-how to install valves and springs. I had someone else do this.
However, in my absentmindedness I forgot to install the oil galley plug before having the head assembled.
Can I tap the block for the plug now that it is all assembled? This is on a b18c1
Thank you
Thank you
DO IT ON ALL FOURS
Re: Oil Galley plug on a b20v
First, what exactly are you calling the oil gallery plug so everyone is on the same page? You say B20V in title but B18C1 in thread. Which is it?
DO IT ON ALL FOURS
You must take the head off and plug it or you will have a massive oil leak there. When you pull the head off you will see the oil supply passage makes a 90* turn inside. No way to do it with the head on.
I'm looking into getting it welded shut, however, I'd like to not have it machined afterwards.
DO IT ON ALL FOURS
Oh, when you said "before head was assembled" I automatically assumed it was installed. My bad. It can be done assembled but it isn't preferred. Put some grease in the hole and on the tap. Use a vacuum after you are done and a rag in the hole as best you can. After that use some brake cleaner. Welding is another option but most people don't want to deck their head if they don't have to.
DO IT ON ALL FOURS
It's not really an option. Unless you are fine with them sanding it down (preferably over grinding anyways) and using some type of sealant that will most likely fail anyways? No matter how good the welder is its almost impossible to not have some sort of decking issue after welding the hole shut and isn't worth the risk anyways. It can be checked with a straight edge of course and make your decision from there.
I got the head back after having it welded.
It does have a little bit of a rise to it, so I'll try to work it down a little. I'd like to not have to deck it as my P2V clearance is already so tight.
Don't really agree with welding it. Now you have to trace out and drill if you want to use it again on a vtec block. That head looks like it could use a resurface anyway.
I was between a rock and a hard place, this DD project had been sitting for far too long and I need results, ha. I was having a hell of a time tapping it.
Went ahead and had it resurfaced. The shop found 2 exhaust valves that weren't sealing fully, so they took care of that as well.
Big shout-out to RJT Machine in Lawrence, Ma. They dropped everything they were doing and took care of me. I was a first-time customer there, and I made the 1.5 hour trek to their door and they definitely hooked it up.
Shiny pics:
Shiny pics:
