New B20VTEC Build - What headgasket company & thickness are recommended?
Old 10-28-2020, 05:22 AM
hondahead2020's Avatar
Default New B20VTEC Build - What headgasket company & thickness are recommended?
new to honda tech might be in the right place.
i have a b20b bottom end with b16b pistons and a p73 gsr head that’s been milled .008.the head is built with type r cams.my questions is does/if someone has a similar build anyone have a recommendation on what thickness of a head gasket to use.i’m trying to get away with just a little conservative build and using pump gas. but afraid the compression ratio will end that real quick.not looking for crazy power yet just some decent gains. thanks in advance
Old 10-28-2020, 08:20 PM
JRCivic1's Avatar
Default re: New B20VTEC Build - What headgasket company & thickness are recommended?
Factory Honda B16B pistons do not fit a B20B block... what brand of pistons do you have ? Pistons with domes that big in a long stroke engine will make really big compression... not a conservative build at all. Assuming your head has in fact only been milled .008", you will need to use a head gasket with a thickness of .040" to get things back close to the stock geometry.
Old 10-29-2020, 12:46 AM
K20.ek's Avatar
P73 gsr head... 🤔 must be new hybrid.
Old 10-29-2020, 01:24 AM
nippon racing
Old 10-29-2020, 02:08 AM
typo 😅
Old 11-09-2020, 04:15 AM
90da4dr's Avatar
What size are they. For a b20 motor you need at least 84mm pistons at stock bore.
Old 11-09-2020, 05:29 AM
its all put together correctly. just wanted to know if there was a recommendation on a size head gasket
Old 11-09-2020, 06:54 PM
K20.ek's Avatar
84mm oem or je pro seal mls headgasket will do just fine.
