NGK spark plugs and msd ignition
i have jdm gsr motor and i'm going to get some new ngk spark plugs. i have the complete msd sci ignition kit.
what gap should i set my spark plugs at? stock gap is .044
Re: NGK spark plugs and msd ignition (hondaeg8)
A bigger spark plug gap means more power but there is a certain point you can gap to before you lose efficiency of the spark, I would just say gap them @ 0.40 and see how it runs, then if you want go bigger gap but for driving on the street you really dont need to worry about gapping bigger to make power, your not going to be able to tell a difference.
Re: (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">are the 7e's the stock heat range or one degree colder?</TD></TR></TABLE>
7 is colder, stock for factory hondas are usually 5-6. I use NGK BKR7E-11s, they are cheap too.
Re: (LSVTEC 91 Civic)
so the 7's are one heat range colder....could i use a 55-60 shot of zex on these plugs? would i be okay using these spark plugs?
digital sol
03-31-2007 03:10 PM
