Ported GSR head, need advice on this!
The Old One
Re: Ported GSR head, need advice on this!
If you look closely, you can see that the entire stock valve guide was tapered from where it breaks into the port all the way to the tip. It's also tapered in the rear.
We were doing this back in the days when most of the castings we received still had stock guides that didn't have much wear. These days, pretty much every used head we see requires guide replacement and we use our radically curve-tapered Aero guides, as they offer maximum valve support with minimal flow-interfering cross-section.
At any rate, you should be in good shape if your head is like the one in the picture, but be fully aware that should you replace the guides in a head that's ported like that one, the new guide's OD's must be no larger than those of the stock guides, or the port will crack.
...And heating the head and freezing the new guides will also be essential when replacing them.
wel on my head the guides are not tapered but the boss deffinately looks like that.
so should i replace the guides or am i good to go?
RagingAngel
01-21-2003 10:16 AM
