Are my valve seals bad?
Rebuilt my JDM B18C (R) about 20,000 kms ago (after 117,000 kms) with all new seals rings and gaskets.
Brand new valvetrain as well with ARP hardware.
About 6,000 kms ago, I started consuming oil about 1qt Honda 10w30 every 1000+ kms.
The engine burned clean though, no smoke.
About 3000 kms ago, a pal told me he saw some smoke coming out my exhaust. It has gotten progressively worse, and now, it smokes a lot under deceleration, at stop lights and when I start up for the 1st time for the day
I have changed to 20w50 Castrol syntec blend and it burns about a qt every 700kms still.
The smell is awful and the smoke is embarrassing.
It seems like valve seals to me. But what would cause them to go bad in 20,000 kms?
BTW I drive this car about 80kms/day, with lots of trips into VTEC.
JDM 96 spec ITR
JDM 96 spec ITR
Re: Are my valve seals bad?
When you say brand new valve train, does that include new valves as well? Anyways, it does sound like bad valve stem seals.
JDM 96 spec ITR
JDM 96 spec ITR
Yeah, new valve stem seals as well.
I bought Skunk2 flat faced valves as I didn't like the condition of my old ones.
Someone told me, maybe I pressed them too hard when installing them. :S I dunno!
erikiksaz1, the smoking doesn't stop.
If I drive hard and come to a complete stop, a cloud of smoke will follow me.
Also, I noticed my oil light taking a few seconds to turn off (after starting).
Does this have anything to do with the problem?
i had/still have the same problem. i drive a 1998dc2 gsr and my car smokes under decelleration as well as ALOT of smoke, and burning oil. i had my valvestem seals changed by a reputable machinist and also had GE head studs put in. It STILL burns oil and blows out smoke and smells. Ive asked alot of people and they say its the piston rings.
Smoke under decel generally is caused by oil getting by the intake valve stems. Just because you had your stem seals replaced doesn't mean they are sealing. If your stem to guide clearance is excessive the seals will be useless. If you do have bad rings, it's the oil control rings that are the problem, not the compression rings. Oil control rings do just that - they control oil consumption. They do not seal anything. That is why a compression and leakdown test is useless for diagnosing an oil consumption problem.
On pretty much every honda I have had that was smoking and burning oil from decel/high vacuum the problem was the rings. I have installed valve seals for customers that requested it, but it never does anything.
I think the negative pressure pulls the oil up past the poorly sealing rings, many times they are stuck into the ring grooves from carbon and oil sludge buildup.
Also, rebuilt engines can suffer from damaged oil scraper rings because they are thin and easily damaged when installing the piston into the cylinder. Cheap or improperly used ring compressors can cause big problems.
The only thing I probably didn't mention was that I had some Skunk2 Pro 2 cams installed for the last 40 days (took them out yesterday). That and the fact that when I pulled my spark plugs, they indicated that I was running extremely rich, although my wideband's richest reading was 12.7 at high rpm.
piotrush
01-31-2006 07:38 AM
piotrush
12-10-2005 08:44 PM
