most horsepower ever made on naturally aspirated LS motor (fully built) ??? - Honda-Tech
Old 01-10-2007, 09:45 PM   #1
myke's Avatar
Location: South LA...107th and fig to be exact...for the foo
Default most horsepower ever made on naturally aspirated LS motor (fully built) ???
any one have any numbers? preferably fully built dynos....im thinking of putting one together just to see how much hp i can squeeze out of it
myke is offline   Reply With Quote
Old 01-10-2007, 10:09 PM   #2
ABK
ABK's Avatar
Default Re: most horsepower ever made on naturally aspirated LS motor (fully built) ??? (myke)
with what head? And how big of stroke and bore?
ABK is offline   Reply With Quote
Old 01-10-2007, 10:21 PM   #3
Hardt's Avatar
Default Re:
There was a guy in SD that had a 86x99 2.3L carb'd LS motor making 248 whp.
Hardt is offline   Reply With Quote
Old 01-10-2007, 11:00 PM   #4
smileycvc's Avatar
Default Re: Re: (Hardt)
Quote:
Im assuming thats without a Vtec head? If that with a vtec head thats not that much.
smileycvc is offline   Reply With Quote
Old 01-10-2007, 11:15 PM   #5
Combustion Contraption's Avatar
Ive made over 400 NA whp on an LS(1)
Combustion Contraption is offline   Reply With Quote
Old 01-11-2007, 07:47 AM   #6
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
Default Re: (Combustion Contraption)
Quote:
Hahaha I was waiting for someone to do that. WELL SUM-BITCH my LS2 makes 400 OUT THE BOX!!!!
Why build an LS non-vtec tho? seems like trying to squeeze juice from a rock.
ComeOnKip is offline   Reply With Quote
Old 01-11-2007, 12:45 PM   #7
ExospeedAMcrx's Avatar
Default Re: (ComeOnKip)
Quote:
why not? Not everyone is going for 500+hp.
Last time I checked, most people just need in the 300s for a good daily driven pump gas turbo setup.
ExospeedAMcrx is offline   Reply With Quote
Old 01-11-2007, 02:26 PM   #8
Fezzie's Avatar
Default Re: (exospeedAMcrx)
ive seen a couple fully built ls motors and they were real nice, so i see no prob with a non vtec motor
Fezzie is offline   Reply With Quote
Old 01-11-2007, 04:55 PM   #9
ComeOnKip's Avatar
read the title. N/A. And I fully understand that building a street car and building a race car are two different beasts of burden, but for NA horsepower in either, it seems like a vtec head would be an obvious choice.
But theres still people strapping superchargers on their flatheads, so more power to him.
Old 01-11-2007, 04:58 PM   #10
I've seen setups making 240s on FULLY built setups.
You can make 200hp on a basic streetable setup with LS.
Old 01-11-2007, 07:26 PM   #11
ComeOnKip's Avatar
and more power to them. is that 200 wheel?
Old 01-11-2007, 07:32 PM   #12
yes 200whp.
Old 01-11-2007, 07:50 PM   #13
myke's Avatar
Default Re: most horsepower ever made on naturally aspirated LS motor (ABK)
Quote:
thinking of going with 86 x 95...with an ls head of course...maybe squareport (thank God that my buddy is a well known head porter lol) hehe...my hp goal is 250-260 whp
Modified by myke at 8:10 PM 1/11/2007
Old 01-11-2007, 07:50 PM   #14
bambam's Avatar
Threads/Dynos/Links?
bambam is offline   Reply With Quote
Old 01-11-2007, 07:54 PM   #15
87mugenprocr-x's Avatar
Vtec is not what is generating these high horsepower numbers, it is merely providing a more broad power curve. Using a high lobe camshaft to expoloit volumetric effiecency is what makes power(along with a host of other things), these high lobe camshafts do not require Vtec.
Julian
87mugenprocr-x is offline   Reply With Quote
Old 01-11-2007, 08:00 PM   #16
Default Re: (bambam)
Quote:
Forums/internet, pic hosting werent easily accessible back in the late 90s. I've just seen local setups here in SoCal make the power, but not PRAISED and advertised on forums like we do every single thing today.
There were a few well known LS All Motor setups that were talked about in the scene around that time and a couple were even in Magazines. maybe you can remember or recall one of them.. it was a red DC all motor LS, I think it was around 98-99 or so.
Old 01-11-2007, 08:08 PM   #17
Default Re: most horsepower ever made on naturally aspirated LS motor (myke)
Quote:
the easy part is the compression and bore. The part you have to plan around on this motor is the cam you are using.
We did an 81.5mm 14:1 LS setup a couple years ago. the class rules limited the bore size so we couldnt go bigger. it ran our Stage 4 LS cams which we matched the custom piston to. It was planned to be carburated and mated to a 2 speed transmission for Circle track. Initial dyno results were about 203whp. The car was put in a tube chassis Monte Carlo body. I lost track of the guy so I never knew what it made after he eventually got more jets for the carbs he was using.
Old 01-11-2007, 08:09 PM   #18
SIXTY's Avatar
DPR??
SIXTY is offline   Reply With Quote
Old 01-11-2007, 08:12 PM   #19
myke's Avatar
Default Re: (SIXTY)
the red DC i believe is mike the kid from lucky racing.....my friend ported that head when he was working at DPR
Old 01-11-2007, 08:13 PM   #20
Default Re: (SIXTY)
ya that was the one in the magazines. there were a few more after that was done but not high profile people u know. it was different back then.. we just learned about setups from word of mouth or seeing them at the track.. no HT to tell the whole world what you did. hehe
Old 01-11-2007, 08:17 PM   #21
SIXTY's Avatar
Yeah it was like noone had names...that guy with the white gsr hatch or the fool with the black h22 coupe
Old 01-11-2007, 08:27 PM   #22
Default Re: (SIXTY)
Quote:
haha yup that was so cal racing scene.
you were either called:
"that dood with the (insert car color) (insert engine type) (insert car type)"
or
"that foo with the (insert car color) (insert engine type) (insert car type)"
Old 01-11-2007, 09:33 PM   #23
ABK
ABK's Avatar
Default Re: (87mugenprocr-x)
yea but unless you run pr8 head valves are 31mm instead of 33mm. And I believe that non vtec head cannot run really high lift due to it's rockers (or someshit like that) I might be wrong.
Vtec heads also flow more, so it's cheaper just to run a vtec head.
Old 01-12-2007, 12:47 AM   #24
bambam's Avatar
Quote:
Julian
it's not the process of vtec, it's the ability to run a larger lobe for high rpms and still idle on smaller lobes.
Vtec head's have larger ports, better shaped ports, larger valves, better shaped combustion chambers, better rocker assemblies, better springs, lighter valves (ITR), better intake manifold designs, etc.....
There's no doubt that a vtec head is superior. It's not opinion, but fact. You'll always be able to make more power out of a vtec head.
Old 01-12-2007, 12:48 AM   #25
bambam's Avatar
Good luck. If I were you, i'd set my goals near 180whp first. 250 whp would most likely be the most power ever documented out of an LS head.
hx40 hp? 88_hatch_ls Forced Induction 28 12-05-2012 07:58 AM
B18C5 Rattling?! roudiiboii Forced Induction 9 08-12-2011 04:12 PM
wtb: fully built b series motor itsanr Want to Buy 5 11-20-2009 08:40 AM
fully built ls head..need one please slows2k Want to Buy 10 09-25-2006 08:25 AM
fully built ls pic apron8 Honda CRX / EF Civic (1988 - 1991) 8 06-02-2003 05:17 PM
Tags
24, aspirated, built, engine, fully, highest, honda, horsepower, hp, ls, made, maximum, motor, naturally, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
