which mark is TDC on the flywheel
Old 01-10-2004, 06:55 PM
* B A N N E D *
turbob16's Avatar
Default which mark is TDC on the flywheel
i was helping a friend do a swap, h22 into an accord. im still confused on which mark on the flywheel is TDC. theres a white plus sign mark and a white dash and of course a red mark. but i cant figure out if its the white plus sign or white dash, cause right now its on the white plus mark. and when trying to crank theres nothin. it has spark and fuel and the compression looks good. help. thanks
Old 01-11-2004, 09:48 PM
* B A N N E D *
turbob16's Avatar
Default Re: which mark is TDC on the flywheel (turbob16)
thanks for the help
Old 01-11-2004, 11:14 PM
chris@allmotor.net's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob16 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help</TD></TR></TABLE>
lol, I actually laughed when I read that, seems to typical.
Old 01-12-2004, 12:46 AM
vteczone's Avatar
correct me if im wrong...but i think there isnt any tdc mark on the flywheel..
Old 01-12-2004, 01:08 AM
JDMlyfestyle's Avatar
i didnt think so either i believe he is referring to the crank
Old 01-13-2004, 07:06 PM
B20vtec86crx's Avatar
Default Re: (JDMlifestyle)
he's right about marks on flywheel...accord and prelude timing marks are on flywheel not crank pulley.. the pink/red mark is the ignition timing mark ..the white line by itself is the tdc mark( on fly wheel.)
Old 01-13-2004, 08:07 PM
eg6h8k's Avatar
Default Re: (B20vtec86crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20vtec86crx &raquo;</TD></TR><TR><TD CLASS="quote">he's right about marks on flywheel...accord and prelude timing marks are on flywheel not crank pulley.. the pink/red mark is the ignition timing mark ..the white line by itself is the tdc mark( on fly wheel.)</TD></TR></TABLE>
so u have to have access to the FW..to check TDC..wtf? i'm lost?
Old 01-14-2004, 05:54 PM
Default Re: (eg6h8k)
there 's a square window between block and tranny ..plugged with square rubber piece with handle ..about 1"X1" square..just remove the plug to check your timing ...you can see needle pointing at flywheel,,
Old 01-17-2004, 11:39 AM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">i didnt think so either i believe he is referring to the crank </TD></TR></TABLE>
Old 01-17-2004, 07:03 PM
hotintegranights's Avatar
Default Re: (CleenSi)
yet another reason not to get a h22.
yep the h22 flywheels have a timing mark if its not properly allign to the white line your motor will not crank up.
RACING INTEGRATION
11-22-2008 09:02 AM
music462
08-22-2008 04:20 PM
y49crxsi
02-08-2005 06:09 PM
SoCaLNaTIvE
08-10-2003 12:44 PM
Quick Reply: which mark is TDC on the flywheel
