gsr pistons and rods in a ls/vtec
Old 01-22-2008, 04:20 PM
Jdmsolutions's Avatar
Default gsr pistons and rods in a ls/vtec
i built a completley stock ls/vtec and want to no if i can use gsr pistons and rods to make it more reliable?
Old 01-23-2008, 10:50 AM
projectcivicjp's Avatar
Default Re: gsr pistons and rods in a ls/vtec (Jdmsolutions)
if you are running a ls crank you have to use ls rods but you can you gsr pistons
Old 01-23-2008, 05:59 PM
b-vtec's Avatar
Default Re: gsr pistons and rods in a ls/vtec (projectcivicjp)
You have to use the rods because there is no oil squirter's in a ls block to cool down the pistons... but i would go with type r pistons.
Old 01-23-2008, 09:05 PM
been there done that
doood's Avatar
Default Re: gsr pistons and rods in a ls/vtec (b-vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-vtec &raquo;</TD></TR><TR><TD CLASS="quote">You have to use the rods because there is no oil squirter's in a ls block to cool down the pistons... but i would go with type r pistons. </TD></TR></TABLE>
so what do the rods and squirters have to do with each other?
Old 01-23-2008, 11:42 PM
VRD^sam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectcivicjp &raquo;</TD></TR><TR><TD CLASS="quote">if you are running a ls crank you have to use ls rods but you can you gsr pistons</TD></TR></TABLE>
Old 01-24-2008, 08:03 PM
Default Re: gsr pistons and rods in a ls/vtec (VRD^sam)
would you recommend itr or ctr?
Old 01-24-2008, 08:18 PM
.I.Need.Money.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">would you recommend itr or ctr?</TD></TR></TABLE>
P30
Old 01-24-2008, 08:46 PM
iKhmaiFoSho's Avatar
Default Re: gsr pistons and rods in a ls/vtec (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
P30 </TD></TR></TABLE>
double , a bit more compression than itr but less than ctr pistons; keep it simple for less headaches.
Old 01-25-2008, 04:30 PM
brad5308's Avatar
x3 with the p30's if you can get them, if not the pr3's/itrs are not much less. as for the gsr rods / pistons ? you must use the proper crank and rod combo- pistons are interchangable as you know. you can put a gsr crank and rods in a ls or vice versa.
Old 01-25-2008, 06:33 PM
all-mtr-teg's Avatar
Default Re: gsr pistons and rods in a ls/vtec (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
so what do the rods and squirters have to do with each other?</TD></TR></TABLE>
What he means is that since the ls block doesn't have oil squirters like a gsr block, he would have to use the ls rods cause they have oil channels that allow oil to cool down the pistons.
Also to the OP, do some research on the crank stroke and rod lengths of both ls and gsr setups, then decide on if it would be wise to use an ls crank and gsr rods.
Old 02-25-2008, 08:30 PM
tealsvteceg's Avatar
Default Re: gsr pistons and rods in a ls/vtec (all-mtr-teg)
what do p30 pistons come out of? whats the comparison to p72 pistons
delsol456
03-05-2008 05:37 PM
ys1civicsi
02-04-2008 06:44 AM
spoonzdelsol
12
08-07-2005 08:13 PM
SoOHiGH
05-29-2005 10:15 PM
Quick Reply: gsr pistons and rods in a ls/vtec
