LS cams vs. B20 cams? - Honda-Tech
Old 02-15-2008, 06:45 AM   #1
civiconfire's Avatar
Default LS cams vs. B20 cams?
from what i understand Ls cams are a little better than the stock b20.
i have a b20... and some cams from a 90, or 91 DA. i know it cant be much of a difference, but it wont cost me anything but cam seals, a valve cover gasket, and my time. so anyone have any input on this? cam specs?
civiconfire is offline   Reply With Quote
Old 02-15-2008, 01:57 PM   #2
Natural Aspirations's Avatar
The obd-2 LS cams are "said" to be a little bigger than the B20's. VERY VERY small difference. Once again it only applys to the newer cams.
Natural Aspirations is offline   Reply With Quote
Old 02-15-2008, 02:05 PM   #3
Default Re: (Natural Aspirations)
Not worth it. Lash to 0.006/0.007 and advance the intake a lil FTMW.
Pho-ShizaaaY. PopoZ-YOW!!!
Rocket is offline   Reply With Quote
Old 02-15-2008, 05:20 PM   #4
JCushing's Avatar
Default Re: (Master of the Universe)
a set of regrinds would be worth your time, messing around with stock cams isnt. however if you insist put in either obd2 LS cams or B20Z cams... b20b cams are the smallest non vtec cams there are
JCushing is offline   Reply With Quote
Old 02-15-2008, 09:43 PM   #5
alright. thanks guys im just going to leave it as is. i do not have the obd2 cams they are obd0.
Old 02-16-2008, 03:27 PM   #6
4door93civic's Avatar
Default Re: (civiconfire)
doesnt make sense. my buddy has a ls out of a 90 integra we ran stock cams then 94-up cams then b20 cams the car made the most power with the b20 cams.
4door93civic is offline   Reply With Quote
Old 02-16-2008, 03:50 PM   #7
Combustion Contraption's Avatar
Default Re: (4door93civic)
Quote:
Just knowing one set of cams is "bigger" than the other really doesnt tell you everything you need to know. I dont know if the LSA of all those cams is the same or not. Tighter LSA's usually make more peak power while sacrificing low and mid. Bigger engines can get away with tighter LSA's because they have more cylinder to feed. Maybe the b20 cams have a tighter LSA and thats why they made more peak power on your friends LS despite being "smaller".
Combustion Contraption is offline   Reply With Quote
Old 02-16-2008, 05:08 PM   #8
JCushing's Avatar
Default Re: (Combustion Contraption)
maybe its because he didnt say wich b20 cams he was using
b20b cams and b20z cams are totally different. b20b cams have only like 9mm lift... b20z have 10mm
Old 02-16-2008, 06:16 PM   #9
Default Re: (JCushing)
sorry we were running b20z cams...i was tyold they were jdm b20 cams but im not sure.
Old 04-26-2008, 07:43 PM   #10
fin781's Avatar
jdm b20 cams have a 15mm lift, only in japan. use em. j/k im running a b20b4 in my crx and i swapped to some ls cams just because they were free, never even ran the b20 ones. but 1mm your really just noit going to be able to tell, notlike vetech . damn ill drink another
fin781 is offline   Reply With Quote
Old 04-27-2008, 06:58 AM   #11
JCushing's Avatar
Default Re: (fin781)
Quote:
really? cause the difference between GSR cams and type R cams is less than 1 mm, and theres less than 1mm difference from type R cams to skunk2 stage 2
theres also less than 1mm difference between stock LS b18b cams and crower 403's
i think i made my point
Old 04-27-2008, 08:43 PM   #12
gh3tt0_boi's Avatar
Default Re: LS cams vs. B20 cams? (civiconfire)
should i go b20 or ls...?
gh3tt0_boi is offline   Reply With Quote
Old 04-28-2008, 01:21 PM   #13
JCushing's Avatar
Default Re: LS cams vs. B20 cams? (gh3tt0_boi)
read the post
Old 04-28-2008, 02:21 PM   #14
JakeSpec's Avatar
[QUOTE=Master of the Universe]Not worth it. Lash to 0.006/0.007
good setting!
JakeSpec is offline   Reply With Quote
Old 09-30-2010, 11:40 AM   #15
AZGS00's Avatar
OMG ALL YOU PPL ARE ****ING RETARDED
NOT ONE MENTION OF DURATION OR OVERLAP IN THIS ENTIRE THREAD!
-tighter valve lash creates more actual duration which is why it gains power
-advancing the intake cam increases overlap which is why it makes power
1mm of lift separates ITR vs the Sk2 cams? how about duration, overlap, ramp rates....
you ppl fail. ive been looking for cam specs and i get this ****
AZGS00 is offline   Reply With Quote
B20Z in my DC, swap to LS cams or keep CRV cams?? turbodcxbro Acura Integra 7 12-01-2010 07:31 PM
Can I use b20 cams on an ls head? raidacaipo All Motor / Naturally Aspirated 12 09-13-2010 07:30 PM
CRV - Replaced head with LS Integra head Question raidacaipo Honda Element & CR-V 5 07-28-2010 12:36 PM
B20 cams for LS turbo? silver_nteg Forced Induction 9 03-30-2004 10:02 PM
B20Z cams vs B18B cams, whats the difference. sloazzbimmer Acura Integra 13 09-16-2001 11:22 PM
Tags
acura, b20, b20b, b20z, bigger, cams, difference, head, hondatech, jdm, lash, lift, ls, p8r, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
