Low End Torque - Honda-Tech
Low End Torque
Old 12-11-2011, 07:51 AM   #1
Icon6 Low End Torque
Is There Anything That Doesn't Require Stroking The Motor, Boring Out/Sleeving To Get Good (Better) Low End Torque?
Princeton'sFast is offline   Reply With Quote
Old 12-11-2011, 08:17 AM   #2
DougNuts's Avatar
Default Re: Low End Torque
Compression ratio.
DougNuts is offline   Reply With Quote
Old 12-11-2011, 08:58 AM   #3
Change your gear ratio. What other mods do you have I would guess I/h/e. Maybe try cams. It's hard to say what you can do without knowing your current setup though. So a little more info would make it easier for us to help you.
Jdubbs6101 is offline   Reply With Quote
Old 12-11-2011, 09:56 AM   #4
Icon6 Re: Low End Torque
Well, I Know This Ain't Going Sound Right At All Guys. So No Pokin' Fun LOL. My Friends AT D15B7 DX Is What We Talking About. This Is What He Wants.
*D16Z6 Head (D16Y8 Head Gasket)
Note: He Was Wanting The Head Milled 40 Thousandths...
He Already Has...
*Header
*Short Ram Intake
*2 1/4 Inch Exhaust
*AC Removed
*Coilovers (Front)
Cable From The Transmission Hooked Up To The TB, That Was Ignored...
Maybe Going Bigger On The TB To 68 Or 70MM...
May Get A New Header (4-2-1)...
MOST LIKELY Doing The (Mini Me Swap)...
May Be Running The H Series Automatic/VTec ECU...
The Car Is OBD1 Too...
Old 12-11-2011, 09:57 AM   #5
Was Wanting To Run A Velocity Stack On The Intake Daily But Don't Really Know If The Air/Fuel Ratio Will Be Good With That... He Said He's Wanting To Run A 2 1/2 Inch Exhaust Too...
Old 12-11-2011, 10:03 AM   #6
HYREV2NR's Avatar
Quote:
This!^^^Lately I've been researching TONS of info on this subject. If I don't build a boosted motor I'm just about sold on MFactorie's 4.92 final drive and 3.07 first gear combo in my ITR tranny. If you don't mind a few more revs (400-500) out of your motor then I'd say this just might be your answer. The link shows how it would turn out on my R's tranny with said combo using the MFactory gear calculator. Check it out.
http://teammfactory.com/gearcalculat...ission+1+%26+2
HYREV2NR is offline   Reply With Quote
Old 12-11-2011, 10:10 AM   #7
His Car Is An AT (Automatic) Though... How Am I Supposed To Change The Gear Ratio With That? He Was Wanting To Stay AT And Get As Much Out Of An (AT Mini Me)...
Old 12-11-2011, 11:13 AM   #8
HYREV2NR's Avatar
Sorry, maybe I missed that. Don't know much about anything auto on Hondas.
Old 12-11-2011, 11:16 AM   #9
Same Here LOL.
Old 12-11-2011, 01:09 PM   #10
clean rice's Avatar
If he's serious about gaining more performance, it has to start with ditching the automatic. If he doesn't want to hassle with it, tell him to get rid of the car. Buying anymore bolt-ons at this point is an absolute waste of money.
clean rice is offline   Reply With Quote
Old 12-11-2011, 03:39 PM   #11
HYREV2NR's Avatar
^^^Didn't wanna say that but, yeah. Doing tranny swaps are sometime not worth it. Just get another car.
Old 12-11-2011, 05:50 PM   #12
crazydominicanman's Avatar
New tranny is necessary
crazydominicanman is offline   Reply With Quote
Old 12-11-2011, 05:54 PM   #13
Well if he can't or doesn't want to drive a manual transmission he probably should buy a different car if he wants some performance. Honda auto transmissions aren't very good at hold much torque so.....options are rather limited. I guess you can do the mini-me swap, you don't have to mill the head so much; I think you said 40 thou, just make sure the head is flat and straight. Then get the eBay cold air intake and some type of header and exhaust. But, honestly that's a rather giant waste of cash IMO. Good luck but if he really want performance from an auto just buy a different car. Lol good luck..
Old 12-11-2011, 06:26 PM   #14
Bisimoto Made A 700HP D16Z6 Wagon On An Automatic Transmission... Why Can't We Just Build An All Motor (Mini Me) That's Torquey? Cause I Swear, We Changed The Throttle Body And Ignored The Cable From The Transmission... I Swear He Was Bangin' Gears From 1ST To 2ND... And You Probably Thinkin' I'm Frontin' Hard LOL...
Old 12-11-2011, 06:29 PM   #15
And I'm Really Not LOL. Filter Was Off The Intake And The Bigger Diameter Throttle Body Was Installed. Not Sure Exactly How Big The Throttle Body Was. Came Off My LS Motor And We Was Seeing How His Car Would React. Compared Both TBs And Mine Was Bigger, So We Tried And He Was Bangin' 1ST To 2ND LOL.
Old 12-12-2011, 10:28 AM   #16
clean rice's Avatar
Umm...no.
Old 12-12-2011, 11:31 AM   #17
Quote:
his wagovan is definitely not an automatic. torque and n/a d series should be never be used in the same sentence.
kyden is offline   Reply With Quote
Old 12-12-2011, 11:37 AM   #18
AznBlueBoy's Avatar
get rid of the car and get something else.
Or swap in an h22 or a k24.
And why are you running a H series ecu?
That's just stupid if you have a d series.
AznBlueBoy is offline   Reply With Quote
Old 12-12-2011, 05:08 PM   #19
Ok I didn't figure I would get entertained this greatly logging on today..Please explain to me how an automatic D series with an H22 ecu was banging 1st and 2nd...go ahead..
Old 12-13-2011, 01:54 AM   #20
AznBlueBoy's Avatar
Quote:
because more fuel = more power right?
But seriously, I don't even think it would start with an h22 ecu.
Old 12-13-2011, 06:15 AM   #21
LOL
Old 12-13-2011, 09:39 AM   #22
95eggsr66's Avatar
start with a tune, and what motors are we talking about?
my stock gsr made 125wtq at 5k rpm
95eggsr66 is offline   Reply With Quote
Old 12-17-2011, 11:09 PM   #23
Kennyjai's Avatar
Remove power steering. Less strain on the engine because you won't need to be powering the P/S pump and belt.
Kennyjai is offline   Reply With Quote
Old 12-18-2011, 02:48 PM   #24
Ricer no 7's Avatar
I know this is all motor forum but JRSC is easiest way for low end power. Pick up a used one.
Ricer no 7 is offline   Reply With Quote
Old 12-18-2011, 07:56 PM   #25
Tell your friend to get a torque converter but aftermarket and throw in some stage three cams also port and polish it will be like a stock b16 but auto still gonna spin 2nd trust. Your also gonna want to put higher compression pistons in maybe 12:1 but yeah it needs work.
hondasdohc is offline   Reply With Quote
Increase Low End Torque, Horsepower Gator0302 Honda Civic (2006 - 2015) 12 04-16-2009 06:56 PM
Best wAys for low end torque>? Cornering Artist Honda S2000 40 01-24-2007 05:18 PM
best low end torque dc2long Acura Integra 34 06-21-2006 05:41 PM
Low end torque question snowshooz Honda Accord (1990 - 2002) 1 01-23-2006 01:33 PM
Which has better low end torque? escape2me General Discussion and Debate 62 03-04-2005 12:09 AM
Tags
2005, end, header, honda, huge, losses, low, make, manual, mini, rl, tork, torque, transmission, whit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
