Lmas still Knocking
Lmas still Knocking
I have a Jdm B16 fullybuilt. Skunk2 Valvetrain, Crower stage 2 turbo cams, Aem camgears, PNP head. Well i recently disassembled the whole motor and replaced every seal and bearing with oem Honda parts. At the inital startup i noticed a knocking coming from the head so i replaced the LMAs with Oem 2000 b16 ones and after starting again its still knocking. My question is what else could it be or did i use the wrong ones or are the cams just to agressive?
Re: Lmas still Knocking (Pagley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pagley »</TD></TR><TR><TD CLASS="quote">I have a Jdm B16 fullybuilt. Skunk2 Valvetrain, Crower stage 2 turbo cams, Aem camgears, PNP head. Well i recently disassembled the whole motor and replaced every seal and bearing with oem Honda parts. At the inital startup i noticed a knocking coming from the head so i replaced the LMAs with Oem 2000 b16 ones and after starting again its still knocking. My question is what else could it be or did i use the wrong ones or are the cams just to agressive?</TD></TR></TABLE>
yes if ur turbo cams are equivalent to something like a skunk2 stage 2 cams then ur valve train will be noisier than usaual.
well when i bought the car it had a slight knock coming from the head with the valvetrain and cams in it already but just thought it needed a valve adjustment but i didnt do it since i was pulling the motor out after i installed it again i did the valve adjustment and turned it over and it knocked after i changed the LMAs the knock was lower but still louder than when i first bought it
Trey
12
03-24-2011 01:06 PM
