Intake manifold test results on a 1.8L Edelbrock ITR IBspec Take a look! -Revised
#76
Re: Intake manifold test results on a 1.8L Edelbrock ITR IBspec Take a look! -Revised
Ah good point, you are right. I just provided the link as a better place to buy then the ebay links in this thread. Ive bought a few things from them before.
MikeySpec and BearsEK is who should get our money though. They are providing all of this info for us and the reason everyone now wants a px again.
Profunction Auto
King Motorsports
Profunction Auto
King Motorsports
#78
"This is an old test from a few years back(early to mid 07), i lost the files a while back and took the time to dig them back out and rehost them. I've since updated a little bit on the thread as well"
In the past couple weeks we have had the opportunity to test different intake manifolds on our 1.8L daily driven project.Our tested items were
a stock itr manifold, IBspec ITR manifold, Edelbrock VictorX, and the Edelbrock performerX. The setup on our car is very simple but has proven
to be very effective. It sees roughly about 450 miles a week and runs on nothing but 93octane.
B18c1 block with CTR pistons on gsr rods
All honda bearings,seals,pumps,and belts
pr3 head with portflow standard headwork
Full omnipower valvetrain set
Blox Type 3 cams with skunk2 cam gears
Spark racing long tube header
RSR gt2 exhaust
Buddy club headgasket
Reused over and over thermal intake gasket
professional products 68mm throttle body
Tuned on Crome pro
For each test we just wanted to see what will perform best and give us the best overall powerband for our benefit. We used the same aem 3 inch cold air
for everytest and tuned air fuels and timing accordingly. The only things modified on each manifold was the throttle body opening. We just portmatched
to 68mm to accept our throttle body. All runs are on 93octane and through the exhaust.
Here is our first initial runs with the untouched ITR intake manifold.
We went for our first trip to the track with this 202whp setup. We went 12.6@107.
Then we moved on to the IBspec ITR manifold. For those not familiar with it, it is and oem ITR manifold cut open and cnc ported on the inside.
For those curious on how the two stack up together, here is a layover of the two.
Next up was the VictorX. We already knew it was going to suck ***** on our setup. We just had to know for sure to eliminate any what ifs. It worked out so horrible that i didnt even finish out a full out tune, it wasnt even worth it. So take this chart for what you will, it just doesnt work well with our motor.
Here is a layout of the VictorX vs. the IBmanifold. It speaks for itself.
Next was the perfomerX, which ran away from everything else. Its priced right and fits like ****, but it made some power!
Here is a layout of it against the IBmanifold to give you an idea of the gains.
We went back to the track with 213whp and went home with a 12.2@112.8
As you can see we increased horsepower and torque, but the real gains are in the powerband. At 9k we have 15 more whp. We could rev the car out a little further, but we need to keep this car reliable. Its his only ride to work. We will be returning to the track this thursday in the hunt for 11s. If you noticed on our parts list that there is nothing fancy or expensive, thats not by coincidence. This was originally intended to be a simple budget build for my buddy to do hpde events with. We took it to the dragstrip out of curiousity and now are on the hunt for 11s......on an oem pieced bottom end......on pump gas.....in a true daily driven street car. WISH US LUCK!!!
http://www.youtube.com/watch?v=Htb_wGFNa4Y
The car went as quick as 12.0 and as fast as 114mph. We never got a good dial in after making over 230whp on e85, it should've been good for 11.80's@114+. We soon after built a 2.0L setup that made a good amount of power....and then the car got stolen. Thanks ********.
Just for grief purposes, heres what our new setup(2.0) put out vs. the 1.8L setup.
RSR gt2 exhaust
Tuned on Crome pro
Did you test the victor x and the performer x on the b20 setup?
#79
thanks.
#80
Really? I already posted the graph from a modded PX on a 2064cc. Do you really need a 2000cc test for your E dyno?
#81
I fail at reading. didn't have enough coffee for this exam-filled Monday.
thanks for the reminder.
#82
Here is one we are working on today without the plate welded to the bottom we will see how this way works.
EDIT: Moved pics to a new thread https://honda-tech.com/forums/all-motor-naturally-aspirated-44/kingmotorsports-modded-performer-x-thread-2873074/
#83
#84
I love this thread, threads like this is the only reason why i sign into HT anymore. Good job guys!
#86
The pics posted are in chronological order. This manifold is being modified as we speak. They are by no means finished pieces. He welded the runners on first then cut the plenum off to match the runners because the runner spacing changes when it gets shortened because of the runner angle. I will continue to post pics today. I will START A NEW THREAD now I have taken too much time on Mikey's thread and I haven't heard from him via telephone so I am not sure if he is ready to shoot me.....
#91
awesome thread! so on my b20vtec set up i would be best of with the px or its right?t if so would it be beneficial to get the skunk2 because its supposed to be a slightly better version of the itr right?
#92
Homosexual by choice
ps, thanks mikey for this test. great job as always.
#93
MikeySpec
149
01-25-2015 06:53 PM
b19coupe
13
10-01-2010 09:41 AM
