thermal r&D exhaust vs...?
I'm trying to find some info on 3" exhaust systems for my 89 civic hatchback. The main one I found is the thermal brand exhaust.
Is the 3" stainless steel exhaust from thermal any good as far as fitment? Does it rust quickly?
Is there any other exhaust I should look into?
Re: thermal r&D exhaust vs...?
Worth a shot. Not sure where to stick my O2 sensor, that's why I asked. 36" down from the turbo will probably be somewhere within the Thermal 'catback' system.
OP. I have been looking into piping kits and such, basically a low cost turbo back exhaust. You really can't beat Thermal R&D. It is only 2.75" ID and 3" OD, but most exhausts are like that. For $575 shipping through a HT deal, it's tough to come close. SS pipe kits run $200+ easy, factor in a straight through muffler, hangers, cost of welding/self install/labor (however you get it on the car), and you end up getting really close. I'm hoping a piece of 3" flex pipe welded to the provided flange, plus a Vband on the other side will mate up to my downpipe. My only issue is finding a wideband mounting point at the current moment, which will be easily solved when the system does in fact get here and I test fit it all.
b18sihatch
37
05-25-2006 09:25 PM
