Intake and Exhaust B20v
I'm looking into finally getting my car tuned on the dyno, and I was curious if
I should change the Intake Manifold and Exhaust (catback). Its a daily driver but I'm still looking to get the most out of my setup.
Head:
P72
ITR Valvesprings
CTR Cams
PX Inatake manifold
68mm TB
3in. SRI w/Blox V-stack and filter
Block:
Stock B20z
Exhaust:
Hytech replica header
HKS Hipower
NO catalytic converter
The exhaust I was looking at is a VRS 2.5 piping, and possible the VictorX Intake manifold.
Thanks for the response,
Joe
Head:
P72
ITR Valvesprings
CTR Cams
PX Inatake manifold
68mm TB
Block:
Stock B20z
Exhaust:
HKS Hipower
Joe
Re: Intake and Exhaust B20v
I say tune it with what you have. I also hear that the performer X IM is a good IM for NA, while the Victor X is more suited for turbo applications. On the stock B20z block, I would be careful not to rev the **** out of it with out help. There is a reason why the B20's and the LS blocks aren't meant to rev high due to the bigger stroke an weak rod bolts. just my 2 cents...
I think you should stick with the performer x (get it ported if possible) or maybe get the skunk2 pro manifold and do an intake manifold test between the two for us when you get it dynoed. The victor x is better for 2.0's than 1.8's, but you will still lose significant low and midrange power compared to the performer x. Since you're staying within 200 rpms of the stock rev limit (which is a good idea), you wont be revving high enough to really even gain any power up top from the victor x. You also mentioned it's your daily driver so most of the time I would assume you aren't revving to 7k+ rpms and you mostly stay in the low to mid rpm range so I think you would be much happier with the performer x. That's just my opinion though.
Also, if you don't mind the noise I would look into getting a 3" exhaust.
1.5boosted
01-20-2008 06:33 AM
Suprdave
07-09-2001 12:53 PM
