The Importance of Valve Adjustment - Honda-Tech
Old 07-02-2007, 05:32 AM   #1
D-Rob's Avatar
Default The Importance of Valve Adjustment
Lately I've noticed an increase in valvetrain noise.
I didn't think much of it at first. It seemed to sound 'normal' to what I was used to with the Skunk2 Pro2+'s I have been running since October 2005.
Then, I started to notice a decrease in power on the butt dyno. The car just did not seem to have the top-end it once had.
Finally, the breaking point was at the track this past Friday night. My car, which usually traps 104-105mph was only trapping 96-97mph. (I also ended up limping home because of a broken alternator belt. )
That is when I really thought about the condition of my engine. It just made no sense to lose 7-8mph trap speeds.
So, yesterday the car was 'freshened' up, if you will.
My father and I popped the valve cover off, reset the cam gears to 0 and checked the valve lash.
We found every valve to have .012" of clearance!
Upon tightening them to .007" on the intake side, and .008" on the exhaust, the car sounded 500% healthier.
Also, before the valve adjustment, the car seemed to idle smoothly at 16 degrees of base timing. Now, 21 degrees is the only point at which it will idle, just like it used too.
After the car warmed up, I proceeded to do a few third gear pulls. From 7,500 to 9,000 RPM, the car wanted a bunch more fuel.
Now, she feels like a million bucks.
So, the moral of the story is, if you run BIG HONKIN' cams, check your valve lash often. I had not touched my valvetrain since March of '06 before this. Now, I will be making a point to check/adjust every 6 months.
- Derek
D-Rob is offline   Reply With Quote
Old 07-02-2007, 05:36 AM   #2
1 2 NV's Avatar
Default Re: The Importance of Valve Adjustment (D-Rob)
wow a good informative post in the all motor forum. to you.
i cant agree more with valve adjustment every 3-6 months on a dd car.
1 2 NV is offline   Reply With Quote
Old 07-02-2007, 07:34 AM   #3
ipodhustle's Avatar
Default Re: The Importance of Valve Adjustment (1 2 NV)
shame on you for going that long without a valve adjustment! especially with those big a$$ cams!
good reminder though, a lot of people forget some of the simplest things that should be done regularly, and it really hurts them.
like the guy who didn't clean his K&N filter for over a year. cleaned it, dyno'd it, free'd up like 7whp LOL
ipodhustle is offline   Reply With Quote
Old 07-02-2007, 09:09 AM   #4
ef92b's Avatar
Default Re: The Importance of Valve Adjustment (ipodhustle)
very often we forget those damn basic stuffs.
nice to hear you regained the power loss.
ef92b is offline   Reply With Quote
Old 07-02-2007, 09:12 AM   #5
VVV
VVV's Avatar
My sentiments exactly.Lazy people are morons.
VVV is offline   Reply With Quote
Old 07-02-2007, 09:14 AM   #6
Chris Tune's Avatar
do a check every month.. checking wont take u over 10 - 15 mins anyways... u can even do it will joking with some peeps around since checking it aint that critical.
Chris Tune is offline   Reply With Quote
Old 07-02-2007, 09:16 AM   #7
D-Rob's Avatar
Default Re: The Importance of Valve Adjustment (Chris Tune)
Indeed.
The simplest things are usually the most overlooked.
- Derek
Old 07-02-2007, 10:08 AM   #8
DA_JDM's Avatar
Good post!!! I need to check my valves soon im at the 500miles mark on my new engine and my valves are making a lot of noise when im driving around
Modified by DA_JDM at 12:56 PM 7/2/2007
DA_JDM is offline   Reply With Quote
Old 07-02-2007, 11:48 AM   #9
PirateMcFred's Avatar
Good post D-rob,
It's been a while since I checked the lash on my daily driver nonVTEC build. And considering that it runs .450" lift IN/EX all the time it probably beats the valvetrain even more than the high strung VTEC engines.
I've got something to do tonight!
Pirate
PirateMcFred is offline   Reply With Quote
Old 07-02-2007, 05:53 PM   #10
b20vtech's Avatar
good info!!
b20vtech is offline   Reply With Quote
Old 07-02-2007, 06:00 PM   #11
b19coupe's Avatar
It amazes me how many people come to the dyno with cars that sound like diesels. Nice to see a reminder on H-T
Good on ya mate
b19coupe is offline   Reply With Quote
Old 07-03-2007, 07:13 AM   #12
b20beast978's Avatar
good post!! very useful information
b20beast978 is offline   Reply With Quote
Old 07-18-2007, 07:20 PM   #13
boost_lee's Avatar
great post, im getting my valves re-adjust. this week.
boost_lee is offline   Reply With Quote
Old 07-19-2007, 12:53 AM   #14
MikeSarr_GSR's Avatar
Default Re: The Importance of Valve Adjustment (initial_si)
maintenence posts are helpful these engines can be a real pain
the harder you beat them without knowing how to set them straight
MikeSarr_GSR is offline   Reply With Quote
Old 07-19-2007, 02:22 PM   #15
rvm
rvm's Avatar
good post!
rvm is offline   Reply With Quote
Old 07-19-2007, 07:02 PM   #16
Aquafina's Avatar
Default Re: (rvm)
I adjust my lash every 6,000 miles on my stock Y7.
Aquafina is offline   Reply With Quote
Old 07-19-2007, 08:50 PM   #17
hayabusa160's Avatar
Default Re: (Aquafina)
its important to check it often. i felt a big difference doing one.
hayabusa160 is offline   Reply With Quote
Old 07-19-2007, 10:45 PM   #18
I don't have .007" in my filler Gage,
It Have .006 and .008", Ill recheck mine today..
salman is offline   Reply With Quote
Old 07-20-2007, 05:45 AM   #19
1 2 NV's Avatar
Default Re: (salman)
.007IN .009EX
Old 07-20-2007, 09:06 AM   #20
just had my valve lash set correctly and now my motor doesnt tick like it used to!!
Old 07-20-2007, 09:19 AM   #21
k_civic's Avatar
What its the valve adjusment for Skunk 2 stage 2?
Now i have .008 in .010ex
k_civic is offline   Reply With Quote
Old 07-20-2007, 09:46 AM   #22
b19coupe's Avatar
Default Re: (k_civic)
That's a little loose(but within spec)-valve train a little noisy?
Old 07-20-2007, 10:55 AM   #23
k_civic's Avatar
Default Re: (b19coupe)
Quote:
Not noisy, but a little friction scracht in vtec lobe, only in ex cam( wierd man) just a little... Thats happen with CTR valve spring, now i have Skunk 2 valve spring. Re-adjust the valve .007in-.008ex?
Modified by k_civic at 11:09 AM 7/20/2007
Old 07-31-2007, 03:14 AM   #24
Have the same problem As Derek, few where at .0010 and .0012,
There is a Big difference in performance,
Old 07-31-2007, 08:19 AM   #25
sircrxracer's Avatar
Holy crap i going to do mine now lol thanks Rob
sircrxracer is offline   Reply With Quote
Valve Lash specs keep changing Lsvtecy0 Acura Integra Type-R 11 05-15-2016 12:16 PM
D16Y8 with goodies off a tooth? 09chaplak Honda Civic / Del Sol (1992 - 2000) 31 09-27-2015 09:50 AM
D16Y8 with goodies off a tooth? 09chaplak All Motor / Naturally Aspirated 7 09-24-2015 11:59 PM
Car still idles poorly after installed type r cam Powered by VTEC Honda Civic / Del Sol (1992 - 2000) 7 01-24-2008 01:27 PM
sounds like nails in a can mattie_96 Honda CRX / EF Civic (1988 - 1991) 2 06-18-2006 11:28 PM
Tags
95, adjustment, adjustments, bolt, civic, honda, importance, important, k20a2, lexus, loctite, ons, sc300, spring, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
