How unsafe overbore is for a B18C JDM ?
I've made some research of few forum and every time on the question : What the max overbore can I get from a B18C ? the answer was 82mm is the limit don't go above
But nobody actually explained why, I know the sleeve can be weak at some point but there's still plenty of room, and for a B18C All motor I would though it would be safe enough to go 84mm
What do you people think ? And what's the difference between a B18C type R bore at 84mm and a B20B std ?
Thanks
Romain/Piv
Thanks
Romain/Piv
Re: How unsafe overbore is for a B18C JDM ?
Ok, after comparing B20 and B18C the sleeve will obviously go much too thin compare to a standard block !
I'll stick to 82mm and be safe
bboyoxygen
11-06-2004 07:00 PM
