How to measure cylinder width/roundness? - Honda-Tech
Old 07-08-2005, 02:42 AM   #1
FritzInTN's Avatar
Default How to measure cylinder width/roundness?
I have a block that has some pitting at the top of one of the cylinders where a valve bounced around. Good times.
Before I go about ordering new pistons and having it bored .020 or .040 over, I'd like to know if thats even a viable option. I know there is some tool that measures width inside walls, similar to a micrometer calipers. I'm hoping this will tell me if the pitts are too deep.
Any ideas on the proper name of this tool, or another way to measure the depth of the pits? I really don't want to lug the whole block up to the machine shop more than I have to. I'm a wuss.
FritzInTN is offline   Reply With Quote
Old 07-08-2005, 11:42 AM   #2
rmcdaniels's Avatar
Default Re: How to measure cylinder width/roundness? (FritzInTN)
I have one of these:
http://store.autotoolexpress.com/ate-cen6460.html
If I was buying it over again, I might buy one like this:
http://jcsonlinetoolshed.com/product.php/2130/679/
Or one like this, which I what my local machine shop uses:
http://jcsonlinetoolshed.com/product.php/1093/679/
rmcdaniels is offline   Reply With Quote
Old 07-08-2005, 06:20 PM   #3
hybrid_vtec's Avatar
Default Re: How to measure cylinder width/roundness? (rmcdaniels)
Use and inside micrometer.
hybrid_vtec is offline   Reply With Quote
Old 07-09-2005, 01:28 AM   #4
Default Re: How to measure cylinder width/roundness? (hybrid_vtec)
a) Inside Micrometer
b) telescoping gauges and a set of outside micrometers
c) or even better...cylinder bore gage and a set of outside micrometers.
Either combo will work. c) is what i would use.
3rdGteg is offline   Reply With Quote
can this block be salvaged??? cityofcaterpillars Engine Machining & Assembly 6 07-19-2016 06:10 AM
Tire brands that run narrow CIREf8 Wheel and Tire 1 02-29-2012 01:03 PM
tial spring dimensions integratuner94 Forced Induction 8 03-24-2005 05:05 PM
Cylinder Bore Dial Gauge Question - Getting a proper reading IN VTEC Tech / Misc 11 07-10-2004 07:28 PM
Trunk Width - anyone know it xtnct Honda Civic / Del Sol (1992 - 2000) 5 04-21-2004 07:03 PM
Tags
bore, bounce, cylinder, cylinders, honda, howto, inside, measure, measurement, meaure, mic, micrometer, roundness, surface, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
