how do u wire vtec to a jumper harness??
Old 03-25-2011, 08:15 AM
91 DA B18B1's Avatar
Default how do u wire vtec to a jumper harness??
i have a 91 integra. so all the wiring is obd0. the car had an ls in it. i did a b20 vtec swap on it. i used my ls harness on the motor so the vtec is not wired. i put in a obd1 gsr ecu with using a jumper harness.. i was ganna run vtec to a switch, but i have been reading up on it as found out it isnt a good idea.. my jumper harness for ecu has the wire to run vtec but so i dont know which ones are for vtec (there are no instrutions). cus there is wiring for an extra o2, knock, ect..so if anyone knows how to wire it or know where there is a diagram if it, if you can post the site. thanks
never mind i finally found a thread for it.....
ILLuSiv3
11-24-2011 05:46 AM
JDMjackyboy
05-31-2011 07:03 PM
ungers_21
06-16-2008 05:02 PM
GreddyCivic7
02-10-2007 03:35 PM
JSPECEX
05-18-2005 09:11 PM
Quick Reply: how do u wire vtec to a jumper harness??
