help. b16 starting problems..
well idk if this is in the right forum. but my b16 was running... anyway i was on the highway went over a rough bump and the car died, battery light and oil light come on. pull over right away check the oil and thats fine it. nothing looked wrong.. when i try to start its like it isnt catching and rolling over. the bat light and oil light are staying on, the bat. is fine (lights run fine, sub and speakers running no problems) help me figure out whats wrong! pleeeaase.
sounds like what happeed to my friends gsr , try a new distributer or coils causeone of the oils in the dizzy went bad and that exzactly what his did oil and batt light on
Re: help. b16 starting problems.. (blakh)
Sounds like something with wiring to me. Check all your grounds. I had a similar problem, had to get my car towed over 5 times cause it would randomly shut off. If you turn the ignition on, do you hear the fuel pump turn on? Start doing some troubleshooting. My problem was a bad ground in my ECU.
