H22A Oil Pressure - Honda-Tech
H22A Oil Pressure
Old 01-10-2010, 08:41 PM   #1
88h22_CRX's Avatar
Default H22A Oil Pressure
I am curious what my oil pressure should be. Once its warmed up it sits around 30psi. But, under a load (WOT) it goes from 75psi and up. My autometer gauge stops at 100psi and it sits pretty close to it when at WOT.
The oil I use is 5w20 RP and a Mobil1 filter. My sending unit is on the sandwich plate between the filter and the block, maybe that is why the high numbers?
The engine has roughly 100k miles on it and is internally stock. The oil level is right below the full mark. The oil pan has a small dent to make room for the traction bar install, the car is a CRX (previous owner).
Any info would be great but I think this is normal, just making sure.
88h22_CRX is offline   Reply With Quote
Old 01-11-2010, 01:26 PM   #2
Default Re: H22A Oil Pressure
Mine idles at ~20psi when fully warm with Mobil1 5w30. My Autometer Oil Pressure sending unit is tapped with a T fitting off of the stock oil pressure sensor location. At WOT, my oil pressure seems to be ~85 psi.
Mike95lude is offline   Reply With Quote
Old 01-12-2010, 08:55 AM   #3
flyrod's Avatar
That sounds normal. btw, oil pressure has nothing to do with throttle position...
flyrod is offline   Reply With Quote
Old 10-31-2014, 06:41 AM   #4
What oil pressure do you have at idle and about 7000 rpm? I have 101 psi/7 bar at 7000 rpm. Is that normal? My tuner told that its too high. Thanks guys!
Cho0se is offline   Reply With Quote
d16z6 turbo misfiring at idle and stumbling at wot (pics inside) MN91 Honda Civic / Del Sol (1992 - 2000) 10 10-19-2011 04:39 AM
Turbo d16 bogging hard when at WOT turbo_d Honda Civic / Del Sol (1992 - 2000) 2 11-04-2009 09:06 PM
blowing oil from my endyne crankcase breather filter? boostismycrack Forced Induction 27 02-13-2005 08:29 PM
oil presure guage problem dAng! Kris Forced Induction 8 01-24-2005 01:38 PM
RSX oil filter on ITR Mike K Acura Integra Type-R 24 02-26-2002 01:46 PM
Tags
95, h22, h22a, honda, hondatech, normal, odyssey, oil, press, pressure, sandwich, sending, sensor, stock, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
