h22 msd coil problems i need some help
im installing a msd sc coil a new distributor w/external coil. it was the only one available.
so there is a green wire on the new distributor plug that on my wire harness has no wire no pin. i pined it ran the wire to - coil. i wired positive from the large black/yellow power wire on the 2 wire connector. i started the car it ran for 20-30 seconds and then died and will not start. the key was on and the coil made a slight sizzling noise so i shut the key off and havent messed with it. any ideas?
