QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT
Old 11-07-2008, 11:26 AM
bowdown201's Avatar
Default QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT
does anybody know if everything the ls/vtec kit works with doin it on a b20 instead. Except for the head gasket i know that wont work. and are the arp head studs the same for LS and B20 for the conversion? Thanks in advance
Old 11-07-2008, 11:47 AM
moderator emeritus
98vtec's Avatar
Default Re: QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT (bowdown201)
https://honda-tech.com/zerothread/1676914
did you read that?
Old 11-07-2008, 04:51 PM
patriot's Avatar
Default Re: QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT (98vtec)
what he meant, was yes, it will work. And the great thing about GE is that you can choose your gasket size right on their site when you order. (hint: go .5mm over the bore size you plan on having)
Old 11-10-2008, 02:27 PM
Golden Eagle's Avatar
the gaskets do work just order the kit with the bore of your block and yes head studs are the same for ether block
Old 11-10-2008, 09:30 PM
bowdown201's Avatar
Default Re: QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT (Golden Eagle)
yea but i found an ls vtec kit for cheap but im doin it on a b20 so that gasket wouldnt work right? cause its not the same bore size?
Old 11-11-2008, 01:22 PM
AllMTRWH0R3's Avatar
So yes get b20 gasket.
Old 11-11-2008, 01:30 PM
Default Re: QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT (AllMTRWH0R3)
no i didn't say anything about a b20 gasket i would never sagest using a b20 gasket there junk we use the vtec gaskets overbored and have proven they work time and time again
Modified by Golden Eagle at 2:58 PM 11/11/2008
Old 11-11-2008, 01:44 PM
patriot's Avatar
The GE kits are nice. I ordered my headgaskets .5mm oversize since thats what Honda does because it helps protect the gasket...I think...
jdmstylesi
Performance
201
11-13-2008 03:00 PM
mcyang87
12-29-2007 12:04 PM
Wuman
09-07-2007 07:29 AM
ReV LiMiT
04-29-2005 01:18 PM
DohcVtec1992
01-14-2005 02:24 PM
Quick Reply: QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT
