Gsr Block w/ 81.5 mm Bore. What size CTR pistons??
Old 11-10-2005, 01:32 PM
kidd_drastic's Avatar
Default Gsr Block w/ 81.5 mm Bore. What size CTR pistons??
I have a gsr block w/ 81.5 mm bore. i'm looking to get ctr pistons. Do i get the .25 oversized ctr pistons.
Old 11-10-2005, 01:54 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Gsr Block w/ 81.5 mm Bore. What size CTR pistons?? (kidd_drastic)
you want the 84 mm pistons, just heat up the block first and hammer them in there
Old 11-10-2005, 02:27 PM
Default Re: Gsr Block w/ 81.5 mm Bore. What size CTR pistons?? (dohcMONSTER)
yes i did.
Old 11-10-2005, 02:53 PM
DonF's Avatar
No. If your bore is actually 81.5mm you need 81.5 pistons not 81.25mm pistons. Take it to someone with a inside micrometer.
Old 11-10-2005, 03:26 PM
https://honda-tech.com/zerothread?id=1415277
so this is the wrong information for the block i bought.
Old 11-10-2005, 03:47 PM
PLAN:B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic &raquo;</TD></TR><TR><TD CLASS="quote">I have a gsr block w/ 81.5 mm bore. i'm looking to get ctr pistons. Do i get the .25 oversized ctr pistons.</TD></TR></TABLE>
the info is right:
.020" or .5mm is the piston size the block was bored for.
therefore, you need .020 or .5mm pistons...easy as that. Just call me if you have any questions.
Old 11-11-2005, 07:51 AM
Rollo Lawson's Avatar
hmmmm.....81.5mm PCT's, 18C block......13+/1 c.r. g/l with your project.
Old 11-11-2005, 12:39 PM
4piston's Avatar
Default Re: Gsr Block w/ 81.5 mm Bore. What size CTR pistons?? (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">you want the 84 mm pistons, just heat up the block first and hammer them in there</TD></TR></TABLE>
Ha ha. Made my day.
mymeatb18"
11-12-2005 07:24 PM
94B18B1Teg
12-30-2003 04:35 PM
SLEPTONEG6
12-22-2003 12:10 PM
Mar_DC2
05-17-2003 08:28 PM
2k1 GSR
02-03-2003 09:59 PM
Quick Reply: Gsr Block w/ 81.5 mm Bore. What size CTR pistons??
