fully built JDM D15B
Old 10-26-2009, 05:57 AM
New User
RJ209_EJ2's Avatar
Icon2 fully built JDM D15B
I have a EJ2 that I got about 2 months ago and its got a built D15b7 but I want to swap the engine for a JDM D15b. I was told I can keep the tranny I have on right now, which is a 2000 civic ex tranny with a lightened flywheel and 6puck clutch.
If I swap the engine what will I need, and what are some parts so I can fully build it to about 210hp? i need some items listed via: types of cams, rods, pistons, turbo kits, intakes, manifolds, headers, exhaust systems...basically an idea.
Old 10-26-2009, 06:37 AM
boost ben's Avatar
Default Re: fully built JDM D15B
For 210hp on a d15b your best bet is boost. You could MAYBE hit 210hp N/A but your really going to be into this build. It's no small feet to even break 160whp N/A with a d-series.
Old 10-26-2009, 06:58 AM
Top Ramen's Avatar
Originally Posted by RJ209_EJ2
what are some parts so I can fully build it to about 210hp? Thank you.
Hang a hair dryer on it.
Old 10-27-2009, 01:23 AM
New User
RJ209_EJ2's Avatar
thanks for the input, i was also thinking about building my d15b7 more and then boosting it, is that a good thing?
Old 10-27-2009, 03:49 AM
alterdcreations's Avatar
alittle boost is always a good thing
Old 10-27-2009, 06:57 AM
90efhatch's Avatar
Yes you can keep your trans. Like other have said the best way to get 210 whp is with boost on that motor. I have one in my coupe with bolt ons and its pretty slow.
Old 10-27-2009, 07:37 AM
HT's TOP CHEF
Chef Andre's Avatar
I've seen a few nice all motor single cams but they only made like 150-160whp. I would out the jdm d15 on bosst and call it a day.
Old 10-27-2009, 09:38 AM
1.5Slowmatic's Avatar
or take the money you spend on boost and put it towards gearing. Its not hard to hit 160+ all motor, so add some sweet gearing into the mix and you got yourself a peppy street car for not alot of money. As for the build i would do as follows:
Stock rods and pistons. Mill the deck surface roughly .1" and head .04". Cam of your choosing be it crower, bisi, Comp, exospeed.... Edelbrock intake mani, if you can get it, a decent header like a bisi or SMSP and a 2.5" exhaust. Send your head to steve at CCC and than get a good tune. Its simple and should yeild great results. However, a better platform to build NA is a 1.6 block due to the stroke and rod length. They allow you to run a wide variety of pistons. The D15B is basically stick with stock unless you go custom or can find a set of PMS pistons
Old 10-31-2009, 09:09 AM
effin's Avatar
my jdm d15b made 125whp n 116 torque with a skunk2 manifold, ebay header, rsr exhaust, and aem short ram on stock p08 ecu.... with a tune im sure i can break into the 130 ranges. boost coming soon..........
cpwtheeuwes
Transmission & Drivetrain
06-17-2017 09:37 PM
ALLMOTORCRX20
05-05-2005 09:16 AM
DJ_SaNdOz
08-10-2004 06:55 PM
96b18c
05-31-2003 03:49 PM
FastSS
05-30-2003 12:48 AM
Quick Reply: fully built JDM D15B
