best all motor LS set up??
b18b
b20 p8r head
crower 404 cams.
itr pistons
itr intake
itr header.
i tryed to find info. on thisset up with no luck
b18b1
ported head, crower valve train
crower 403 cams, stock cam gears
jdm p30 pistons
stock lS rods
stock LS computer
stock header
short ram intake
now i found info on this set up putting down about 160-170 HP to the wheels which is enough for me
does anyone have any info on this?? thanks
b20 p8r head
crower 404 cams.
itr pistons
itr intake
itr header.
b18b1
jdm p30 pistons
stock lS rods
stock LS computer
stock header
short ram intake
the second setup that you posted is almost the same setup that i would do.
here is my setup that i would do
b18b1
ported head, crower valvetrain
blox intake manifold or the edelbrock performer x or the skunk2 manifold
crower 404
jdm p30 piston
shot peened ls rods
arp rod bolts (so you can rev high)
arp head studs
itr header
ls computer with hondata s200
short ram intake with velocity stack
here's the link to the setup you posted.
http://hondaswap.com/general-t...31401/
b18b1
crower 404
jdm p30 piston
shot peened ls rods
arp head studs
itr header
not sure on the first setup but i think that the b20 head has bigger valves but i'm not sure. also the itr pistons would not give you a higher compression like the p30 would.
Re: (soto2635)
Combustion chamber bore on the P8R is 84mm vs the cylinder bore of the b18b at 81mm. Not sure what issues this could cause but figured id mention it.
Re: (tincam84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tincam84 »</TD></TR><TR><TD CLASS="quote">Combustion chamber bore on the P8R is 84mm vs the cylinder bore of the b18b at 81mm. Not sure what issues this could cause but figured id mention it.</TD></TR></TABLE>
mainly head gasket issues due to the mismatch and turbulence from the lip caused by the mismatch in bore differences.
Re: (tincam84)
Detonation galore. Don't do it. P8R is great for 84mm bore. Use the LS head for <84mm bore.
ProStreetImport
178
06-12-2006 07:49 PM
The Stance
12
06-28-2005 12:03 PM
STHPERFORMANCE
11-04-2003 12:18 PM
