My Build. all input appreciated GSR motor
Old 01-19-2010, 05:51 PM
streetsold6teeny8's Avatar
Default pr3 pistons w/ gsr rods in gsr block with b16 head?
Will pr3 pistons do me any good with my gsr block and b16 head? What good can i get out of this with the rest of my setup
I've searched but found nothing except for pr3 in full gsr motor but i got a b16 head.. Thanks
Ok I'm kinda on budget here. this is a setup im considering. Any input is greatly appreciated. Im not too knowledgeable on this part.
I have a b18c1 with a b16 head that has type R valvetrain (accordingly). Its how I got it.
So now
PR3 81mm pistons
Stock Gsr rods
Stock gsr block.
JDM B16 Head will be match ported
Skunk2 Cam Gears
ITR Intake Manifold with hondata IM gasket
blueprinted balanced etc
2.5 exhaust
hytech replica
Old 01-19-2010, 06:19 PM
JDM Scott's Avatar
Default Re: My Build. all input appreciated GSR motor
Nice setup
Old 01-19-2010, 06:27 PM
All Motor Mentor
00Red_SiR's Avatar
you don't need to knife edge the crank, especially for street use. You also don't need the CTR crank pulley either, run the stock one. Your throttle body is a little big, I would use stock if I were you on that build or no bigger than a 68mm. No mention of the cams you're using but at that comp ratio, you'd be much better off using something larger than ITR/CTR's. What kind of tuning system are you using?
Old 01-19-2010, 06:34 PM
probably crome pro but i'm not sure yet.. And I cant afford cams right now. I got the stock throttle body.. so ill probably stick to it then..
oh forgot to mention this is for a crx
Old 01-23-2010, 11:10 AM
bump please advise might buy them tonite ....!!!
Old 01-23-2010, 12:31 PM
Natural Aspirations's Avatar
ITR pistons will fit the GSR rods without modification unlike the B16 pistons.
Old 01-23-2010, 12:40 PM
Does that apply to oem only or to both aftermarket... because these are after market and in regards to that i thought oem needed modification to fit them... correct if wrong thanks
Old 01-23-2010, 12:51 PM
88Hatchy's Avatar
Pistons from RaceAxis will clear GSR rods, OEM pistons will not.
Old 01-23-2010, 01:03 PM
IMO the ITR piston is better designed piston as well making no real reason to go with a B16 piston. Any reason you feel more inclined to use the B16 Pistons?
Old 01-23-2010, 01:04 PM
oh ok kool thanks
now any benefits from this piston in my setup...cr gains? power gains etc whether major or not would like to know
Old 01-23-2010, 02:04 PM
OH_1fstgsr's Avatar
I'm running USDM ITR pistons in my GSR. Runs great because of the tuning. Make sure you get it tuned.
About 11.6:1 compression, block and head have been machined a bit.
With GSR cams and the GSR manifold I made 170-175whp.
Then with ITR cams 180-184whp still with the GSR manifold.
I now run a Performer X manifold with ITR cams, no dyno numbers yet, winter gas sucks. I expect 195-200whp.
Not the most budget minded build.
I take it your car is a daily driver, maybe some weekend track duty?
Old 01-23-2010, 02:10 PM
its what some guy had for sale at a good price.. so i wanted to do research with that piston in my setup.. Where would I be able to find a good price for itr pistons?
Old 01-23-2010, 02:14 PM
I'm running a B16 head not gsr... Yes I plan on DD prolly not doing any track time.. RARELY!!! I'm doing this because I have to take the motor apart due to bad rings and I am seeing what I can do for a slight power gain... might as well since im taking it apart.. besides the fact that I saw some guy offer these pistons for a good price..
Old 01-23-2010, 02:17 PM
I was considering CTR pistons but I read it raises comp too high!!! how would that work in my setup? and what head gasket would work best? Considering my setup drops in CR, I would think ctr pistons would be ok but also is the fact that the clearances are too close.. Thanks
Old 01-23-2010, 02:21 PM
If your getting the B16's for a good deal by all means go that route, if you are sure they will work with your GSR rods.
CTR pistons are commonly considered to be a bad designed piston that will make your compression too high.
This looks like a decent deal if you are on a budget
ITR "KIT"
Old 01-23-2010, 02:29 PM
what about
http://cgi.ebay.com/ebaymotors/RS-MA...Q5fAccessories
or the same on in 81.5mm
Hey thanks for your help and everyone else
Old 01-23-2010, 02:32 PM
Sure. RS may be even a little higher quality.
Old 01-23-2010, 02:52 PM
ok kool hey again thanks its what i might be looking into then
Old 01-23-2010, 06:10 PM
OH_1fstgsr's Avatar
Sorry about that. Some how I thought you where running a GSR head.
Old 01-24-2010, 05:38 AM
NP man thanks anyways
d16turbocoupe
12
08-29-2010 10:33 PM
93egSLEEPER
32
12-24-2009 03:26 PM
ctr status
11
05-21-2007 12:42 PM
DC2SIR-G
10-18-2005 02:05 PM
Quick Reply: My Build. all input appreciated GSR motor
