d16z6 vitara Ring End gaps. Specs driven Na then turbo????
Old 08-20-2013, 08:17 PM
EG-SIXV-TEC's Avatar
Default d16z6 vitara Ring End gaps. Specs driven Na then turbo????
i currently gapped my vitara pistons 75.5mm/ eagle rod build d16z6 motors to these specs.
Top .016-.017
Second .018-.019
oils about .021-.022?
im planning on running this motor N/A for a while daily. until i get enough for a turbo my setup all pieced out.
im hella nervous out about if this motor will smoke etc...
will this smoke please let me know
i will run it for a while with N/A
will i run into smoking problems with my engine if i run it with these specs?????
i already gapped them to the specs.
i looked the service manual but i kinda went more than the specs..
says top
.006- .0012 service limit .024 i passed the .012 limit will i smoke?
says second
.012- .018 service limit .028 i passed also the .018 will that cause it????
need opinions and specs anyone used on a d16z6....
Old 08-21-2013, 07:34 AM
blackeg's Avatar
Default Re: d16z6 vitara Ring End gaps. Specs driven Na then turbo????
U are fine. The service limit isnt .012 it was. 024. What is thd piston to wall that you went with? I think my vitara motor was. 016 top and.019 second ring it didnt smoke at all. Get a. Good tune and break in u will be fine
Old 08-21-2013, 07:24 PM
Post Re: d16z6 vitara Ring End gaps. Specs driven Na then turbo????
my machinest told me he went with honda specs limit like .002 - .025
what did your motor specs to??? p2w clearance??? did your motor go NA
i want to run this NA b4 i go turbo thats y
im worried i shouldn't b
Old 08-23-2013, 10:26 PM
opc
opc's Avatar
one of the greatest things about this hobby is the ability to learn patience... if you can just keep saving, and saving, and more saving, run stock until you have the setup of your dreams, it will be worth 10x more than this...
just saying bro..
Old 08-24-2013, 05:21 AM
blackeg's Avatar
no it had the turbo on it, but 99% of the time i was driving not in boost, soo...
i went 75.5mm and i think the piston to wall was set at .003. i dont remember much if any piston slap but i always let my cars runs for a minute or 2 before i start driving them, n/a or turbo.
for the record when people first found out about the vitaras they were just running a hone through on stock bore 75mm and putting the piston in. that very often gives large ptw like .006+ as the vitaras were undersized to have the ptw built into the piston.
just go drive it. make sure than you get some heat into the motor while breaking it in. also know that it will be dogshit slow with the low compression and you will likely have to add multiple degrees of timing to help oout with responsiveness
Old 08-24-2013, 07:15 AM
motoxxxman's Avatar
those ring gap specs are perfectly fine. I actually ran larger gaps than that on my first motor which I ran n/a for 10k miles or so before the turbo got added.
just remember, part throttle n/a is nearly identical to part throttle boosted. so if it doesn't smoke while in vacuum with a turbo, why would it smoke in vacuum n/a?
EG-SIXV-TEC
05-18-2013 12:20 PM
dez6
02-02-2009 05:20 PM
sabremike21
01-03-2009 11:55 AM
xXx Justin xXx
05-13-2002 09:17 PM
Quick Reply: d16z6 vitara Ring End gaps. Specs driven Na then turbo????
