D16z6 with JDM D15B VTEC head
Old 01-15-2011, 12:09 AM
WhiteyW/AHonda's Avatar
Icon2 D16z6 with JDM D15B VTEC head
I recently bought a car that was running a D15B Vtec i had a rod shatter and can't find a replacement rod also it's running PM3 pistons/rods can i put my head onto a d16z6 and have it run and will it be worth it? or should i swap the d16z6 pistons/rods into my d15 block since they are the correct length? won't the d16z6 block with my d15b vtec head put out more power since it's a larger displacement?
Old 01-15-2011, 04:38 PM
N/A
Purpose Built
N/A's Avatar
Default Re: D16z6 with JDM D15B VTEC head
Just get a z6 block or a sohc zc block and slap the head on it
Old 01-15-2011, 05:52 PM
kyosoeg6's Avatar
which "jdm d15b vtec" motor do you have? most of the vtec d15bs i have come across have the same po8 head as the z6 motor.
Old 01-15-2011, 06:40 PM
projectTeG's Avatar
the d15b vtec rod is the exact same rod as the z6 and y8. basically the big journal 1.6 D series rod.
as far as the pistons, they are customs pistons. they have the wrist pin moved up a bit to house the longer rod.
the block is a D15 block. or a Z1 block. you just need to use the actual d15b or Z1 crank to run the d15b vtec rods/[piston combo.
also the d15b(non multi stage vtec one, more or less the obd1 engine) head is the same as a z6 just with a slightly larger cam.
Old 01-15-2011, 06:43 PM
N/A
Purpose Built
N/A's Avatar
Or just find a 1.6 block and call it a day
Old 01-15-2011, 08:00 PM
vtec8200's Avatar
Get a d16a6 or d16y7 block for best results
Old 01-16-2011, 05:14 AM
projectTeG's Avatar
the d15b block has a rod ratio similar to that of a b16b or a b16a. its a nice stout oem D series bottom that can handle alot
Old 01-16-2011, 10:35 AM
i ended up just getting a z6 block and putting my head on it. since it's the P08 head will i just time it as if it's a z6 or change it up a bit since it's a different cam?
Old 09-11-2011, 03:50 PM
rainmanef's Avatar
Anyone else done this swap?
Old 09-11-2011, 04:49 PM
kyosoeg6's Avatar
what swap are you talking about? the d15b head is the same as a z6. well the casting least is a " p08"
chinochanginc
06-28-2009 08:39 PM
JDMTuner4Life
02-24-2007 07:29 AM
CivicHB91
01-23-2003 03:30 PM
Quick Reply: D16z6 with JDM D15B VTEC head
