Car belt noise and various questions
Old 07-19-2011, 06:13 PM
myhondatechacct's Avatar
Default Car belt noise and various questions
I am a car beginner. I want help diagnosing this problem please so I can describe it to the mechanic a little better, and I have other questions too.
While driving my Honda civic automatic with a recently replaced engine and radiator, I started hearing this weird chirping/flapping noise (not squealing) whenever I stepped on the gas pedal. When the car shifts into higher gears the noise gets louder. There is little or no noise when not stepping on the gas pedal.
1. Is this frayed belt causing the noise? It's not the timing belt, but a belt lower than it. I tried looking in the service manual. Maybe it is the A/C belt? A strip of the top layer of the belt is peeling off and is frayed at the end. How big of a problem is this? Here is a picture:
http://imageshack.us/photo/my-images/833/belt1l.jpg/
2. Should I not accelerate jerkily with a new engine? (50K miles, used Japanese engine) Will it be more likely to break a belt or something? Or would you do the opposite and push the engine as much as possible to bring out any problems while the engine is still under warranty?
3. The engine is still "under warranty" for parts and labor, so I will probably bring it back. Should I ask the mechanic about replacing anything else if I bring my car to him? The invoice of the original engine installation says the following parts have been replaced already: timing belt, thermostat with gasket, water pump, cam seal, crank seal, rear main seal, intake gasket, valve cover gasket, oil filter.
4. I am also wondering whether or not the AC stopped working after the engine got replaced, but it has always been weak. It it common for the AC to stop working after engine replacement, and is it easy to do AC work when doing engine work?
5. A youtube video I watched about driving safety recommended glancing at your rear view mirror about every three seconds to be aware of the situation around you. Is this good advice?
6. Someone told me you can position your side mirrors so you don't have to look over your shoulder to check your blind spot. Is that true and is it good advice?
7. I am thinking about starting to do my own oil changes. Is it safer to use 4 jack stands instead of 2? If I only want to jack one end of the car up, is it still possible / safe to use 4 jack stands ? Is my trunk scissors jack fine to start, or should I get a wal mart jack or a $100+ jack online?
myhondatechacct is offline
Old 07-21-2011, 08:21 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Car belt noise and various questions
Looks like you spammed this all over H-T.
1-I don't know. Is that where the sound is coming from? Did you ever pop the hood to check? You read the service manual but you still don't know what belt that is?
Also, does that look normal? Replace the belt regardless.
2-How does one accelerate "jerky"? Better check what your warranty covers before you try to get any free parts/labor out of it.
3-Again. What does the warranty cover? You can bring it back all day long and if it isn't covered you're the one that will have to pay for it.
4-Do you not know the last time you used the A/C? No it's not common. No it's not easy.
5-If you have to ask such questions you should not even be driving. Take a drivers ed course. Did you just get your license?
6-See #5.
7-While you're taking the drivers ed course also think about taking auto shop as well. At the very least learn how to read a service manual. I'm sure even Youtube has a video for oil changes.
grumblemarc is offline
Old 07-21-2011, 02:14 PM
Why don't you tell me how often do you glance at your mirror then?
Old 07-21-2011, 03:29 PM
The Grumpiest
As often as I need to. Your point?
Old 07-21-2011, 08:57 PM
HT White Ops
ShaunRR's Avatar
In efforts to avoid board clutter and confusion, we ask that you please refrain from cross and double posting the same topic across multiple boards.
ShaunRR is offline
myhondatechacct
07-20-2011 07:53 PM
myhondatechacct
07-19-2011 07:54 PM
Liquidice944
Honda Civic (2001 - 2005)
15
08-17-2009 04:24 PM
ludetuner
10-28-2004 05:46 PM
Sam268
06-10-2004 06:10 PM
Quick Reply: Car belt noise and various questions
