help with ls no compression
hey guys, so I have a project acura integra that Ive recently swapped the motor on. The motor was from jdm engine depot in new jersey. So I swapped the motor in and it wouldnt start so i decided to compression check it, and it turns out there is zero compression in all cylinders. Ive tried 3 compression testers and still same results. Unfortunately the warranty was very short so they will not help me what so ever, so I was hoping you guys had some ideas
Re: help with ls no compression
Ya id definitely recommend that.lol Its wierd tho because the only things i hear about jdm engine depot are good things. But i took the cams out so the valves would just stay shut, put some oil in the cyclinders and Ive got about 80 psi in each cylinder
If you took the cams out, how would you get any air in the cylinder " IN cam" to read a compression guage? Or air out to be accurate? The only thing you did is make it easier to use a "leak down tester". You can Google it to find out what it is.
Take out the cams and put air in the cylinders through the spark plug hole and try to see if you hear a leak. Easy way to tell if i valve is bent.
0 compression? Rotate the engine by hand to see if it does rotate. as you rotate it look to see that the cam gear(s) also move.
builtprelude
01-22-2004 10:49 PM
