camshaft bolt problem!!!!!
Old 10-23-2007, 02:19 PM
StreetRiot_DRE's Avatar
Default camshaft bolt problem!!!!!
i recently blew a head gasket and while i was putting it back in i was checking the torque specs for the cam holders and it said 86in-lbs which i have no idea how to get that since im using a torque wrench with ft-lbs... Stupid me i was not reading properly and torqued it to 86ft-lbs... i kinda knew something was wrong because it kept torquing and by the time i realized it i snapped a bolt. So my question is... is it fixable the head and wut is the convertion to ft-lbs?
Old 10-23-2007, 02:51 PM
d16dcoe45's Avatar
Default Re: camshaft bolt problem!!!!! (StreetRiot_DRE)
86 inch/lbs.--
86 divided by 12=7.17 ft/lbs
so 86 in/lbs is roughly 7 ft/lbs of torque
Old 10-23-2007, 03:45 PM
Default Re: camshaft bolt problem!!!!! (d16dcoe45)
yea i did the _/12 too but i wasnt sure if that was the rite way to convert because i tightened another bolt to 7 ft/lb and it just felt too loose......
but my biggest problem is that the bolt that snapped is inside the head and i need to know if tapping it out, or any other method, would work to get it out???????
Old 10-23-2007, 03:49 PM
( o )( o )'s Avatar
did ONLY the head snap off or did part of the threaded bolt come off with it? If you remove the cam cap, is there any bolt material sticking up? perhaps vise-grip pliers would help....
Old 10-23-2007, 04:02 PM
Default Re: camshaft bolt problem!!!!! (( o )( o ))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote">did ONLY the head snap off or did part of the threaded bolt come off with it? If you remove the cam cap, is there any bolt material sticking up? perhaps vise-grip pliers would help....</TD></TR></TABLE>
the bolt snapped in half and inside the hole where it goes so none if it is sticking out
would i be able to run with that 1 bolt missing on just one of the bridges????
Old 10-23-2007, 04:09 PM
( o )( o )'s Avatar
i would not run with one bolt like that.
you are probably going to have to extract it or drill it out and re-thread it.
good luck!!
Old 10-23-2007, 04:14 PM
Old 10-23-2007, 05:49 PM
EJ8CIVIC's Avatar
long time ago my friend snapped one like u did and i ran with it like that
Old 10-23-2007, 05:56 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRiot_DRE &raquo;</TD></TR><TR><TD CLASS="quote">would i be able to run with that 1 bolt missing on just one of the bridges????</TD></TR></TABLE>
Once again, here we have a case of someone just wanting a random stranger off the internet to tell them its OK to take a short-cut.
Have at it, my friend. Have at it.
Old 10-23-2007, 06:34 PM
AccordSleeperZzZ's Avatar
Default Re: camshaft bolt problem!!!!! (Combustion Contraption)
personally, if it was me, i wouldn't risk effing up my engine over a dumb bolt.
i'd pick up a left handed drill and try and dig that sucker out of there.
just my .02
Old 10-23-2007, 06:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
Have at it, my friend. Have at it. </TD></TR></TABLE>
actually i am in search of someone thats had a similar situation or experience but thanks for ur replay because it bumped my post up to the top for more to c..........
Old 10-23-2007, 06:54 PM
Default Re: camshaft bolt problem!!!!! (EJ8CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">long time ago my friend snapped one like u did and i ran with it like that</TD></TR></TABLE>
and did tha car run fine??? or did problem occur, eventually??
Old 10-23-2007, 07:06 PM
all-mtr-teg's Avatar
If the cam cap is alluminum, just weld a nut to the snapped bolt, the weld will only work on the screw and the nut, it wont weld the alluminum, i did that on an oil pump bolt on my gsr block, worked way better than trying to use a bolt extractor on a 6mm bolt.
Old 10-25-2007, 06:44 AM
Lubo_25's Avatar
that head is easily fixable and shouldnt cost anything more than a 12 pack of heineken...a carbide drill, bridgeport, and a careful concentric eyeball will do it right
jakeosbo
04-11-2017 07:23 AM
StreetRiot_DRE
10-23-2007 02:54 PM
jdmboxrocket
10-09-2006 05:47 PM
crxaddikt
13
09-09-2004 07:34 AM
See Are X
02-06-2003 12:31 AM
Quick Reply: camshaft bolt problem!!!!!
