which camshaft best for daily driver with performance on H22A/F20B?
Old 06-16-2011, 08:50 PM
jackiewogn518's Avatar
Default which camshaft best for daily driver with performance on H22A/F20B?
Old 06-16-2011, 09:07 PM
UncleD's Avatar
Default Re: which camshaft best for daily driver with performance on H22A/F20B?
Buy all the cams that are available, dyno tune with each set. Whichever gives you the best powerband - is the "best."
Old 06-16-2011, 09:55 PM
if choose from below....what will u recommend?
1. skunk2
2. BC
3. BLOX
Old 06-16-2011, 10:07 PM
UncleD's Avatar
S2 by far
Old 06-16-2011, 10:12 PM
Y2K Si FBP's Avatar
skunk 2..pro 1
on my h22 no headwork...valvetrain mods...skunk pro 1s...mahle pistons...decent header and 2.75 exhaust...
made 237/168 whp on a dyno dynamics dyno....
with a nice powerband making power up til 8100 rpms.
Old 06-16-2011, 10:59 PM
Originally Posted by Y2K Si FBP
skunk 2..pro 1
thanks! I also interested in sk2 pro1, is it a must to change the valvetrain?
actually...I'm going to install it on F20B head, is it just the same as H22?
Old 06-16-2011, 11:00 PM
S2 by far
Thanks!
Old 06-16-2011, 11:44 PM
HdeucedeuceA's Avatar
I agree. Skunk2 Pro 1's are the way to go. You for sure have to change the valveterain.
I actually have a set BNIB if you're interested.
Old 06-17-2011, 12:30 AM
I'm thinking tuner stage 2 / pro1.....actually dunno what's different....
Old 06-17-2011, 11:25 AM
Moderator
TheShodan's Avatar
Difference between Stage 2 and Pro 1 is larger off-vtec cam lobes to give a bit more linear power than the staged series. I have found the Pro1s to be a much smoother application that still give a good amount of power over the rev range
Old 06-17-2011, 12:01 PM
gheezy's Avatar
if you have the manual f20b the valve springs are a little more stiff than the auto f20b, i've heard somewhere that you can actually run aftermarket stage 2 cams on a stock f20b head, not sure though. anywho if your stuck between choosing tuner 2 or pro 1's go with pro 1's for the better powerband, but both will still need valve spring upgrades at least.
Old 06-17-2011, 12:13 PM
i also notice a H-T member even using pro 2's with stock F20B type-s valvetrain..... but dunno it is real or not....
Old 06-17-2011, 01:27 PM
gstrudler's Avatar
Yep, Skunk2 even mentions this in the product briefs on their website. They intentionally made a larger variance in the lobes in the tuner series to leave the "jump" into VTEC that some people like, whereas the Pro series is meant to have a smooth crossover and better midrange. Tuner 2's are also designed for a higher RPM range than the Pro 1's, so some of it depends on where you want the power. Either one of those necessitates a valvetrain upgrade.
Old 06-17-2011, 01:49 PM
Skunk2Brian's Avatar
Thanks for the recommendations guys. We appreciate it.
Either Tuner 2 or Pro 1 will require valvespring upgrade at a minimum. The lift generated by the vtec lobes will "kaboom" Type S valvesprings.
Old 06-17-2011, 02:13 PM
m_shake's Avatar
Skunk2 pro1's would be great for a daily, plus you would be supporting a company that actually developes parts for us, not shady other businesses that just copy someone else's research
Old 06-17-2011, 05:42 PM
If I want to have more power on midrange rpm......is it go for pro1?
Old 06-17-2011, 11:49 PM
^Correct
Old 06-18-2011, 05:44 PM
Thanks for all the comments!
I would like to know any difference on the installation on s2p1 cam in F20B DOHC head?
Old 06-18-2011, 06:03 PM
Moderator
TheShodan's Avatar
With that... I'd contact Skunk2Brian or call them directly. Not too many F20B cats on this forum.
Moderator
TheShodan's Avatar
QFT!!!!!!!
Old 06-18-2011, 07:11 PM
Thanks! Just PM skunk2Brian....
coomplife05
08-09-2013 02:07 PM
WickedSol
28
01-12-2006 10:18 AM
WickedSol
08-18-2005 03:13 PM
sloaccord
07-22-2001 07:05 PM
Quick Reply: which camshaft best for daily driver with performance on H22A/F20B?
